Hello Guys,
I have the problem again and I now have dump the Boot-up messages from the Mark II Player... It looks like the Hard-drives are not being found upon boot up.
Boot - File Starts here: Ingnore DHCP info below it was not attached to a network.
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #127 Wed Oct 17 16:02:35 BST 2001
empeg-car player (hardware revision 7, serial number 80000457)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-232, ATA DISK drive
hda: IBM-DJSA-232, 30520MB w/1874kB Cache, CHS=62010/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:c
9
Partition check:
hda: [PTBL] [4134/240/63] hda1 < hda5 > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԥjչѕroot (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k initI see this is a developer image!
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplStarti
ng player
empeg-car 2.00-beta3 2001/10/17.
E !! tags.cpp 61: Failed to open tags (0xc0041002).
Rebuild 0ms
3c15be7c DHCP name = lo
3c15be7c DHCP index = 1
3c15be7c DHCP flags = 0x8
3c15be7c DHCP addr = 0.0.0.0
3c15be7c DHCP bcast = 0.0.0.0
3c15be7c DHCP mask = 0.0.0.0
3c15be7c DHCP name = eth0
3c15be7c DHCP index = 2
3c15be7c DHCP flags = 0x1002
3c15be7c DHCP Our mac is 00:02:d7:10:01:c9
3c15be7c DHCP Current IP address is 0.0.0.0
3c15be7c DHCP Broadcast address is 0.0.0.0
3c15be7c DHCP Attempting to open Autonet socket for eth0
3c15be7c DHCP Adding interface eth0
3c15be7c DHCP Sending DHCP discover (eth0)
3c15be7c DHCP Extensions present: 61 53 55 57
3c15be7c DHCP Testing Autonet address 169.254.199.231
Prolux 4 empeg car - 1.1090 Oct 17 2001
Vcb: 0x405ae000
3c15be7d DHCP Sending DHCP discover (eth0)
3c15be7d DHCP Extensions present: 61 53 55 57
E !! local_audio_component.cpp 543: Invalid tune information for FID 0x0. This i
s bad.
3c15be7e DHCP Sending DHCP discover (eth0)
3c15be7e DHCP Extensions present: 61 53 55 57
3c15be7f DHCP Sending DHCP discover (eth0)
3c15be7f DHCP Extensions present: 61 53 55 57
3c15be80 DHCP Sending DHCP discover (eth0)
3c15be80 DHCP Extensions present: 61 53 55 57
3c15be81 DHCP Sending DHCP discover (eth0)
3c15be81 DHCP Extensions present: 61 53 55 57
3c15be82 DHCP Sending DHCP discover (eth0)
3c15be82 DHCP Extensions present: 61 53 55 57
3c15be83 DHCP Sending DHCP discover (eth0)
3c15be83 DHCP Extensions present: 61 53 55 57
3c15be83 DHCP Testing Autonet address 169.254.199.231
3c15be84 DHCP Sending DHCP discover (eth0)
3c15be84 DHCP Extensions present: 61 53 55 57
3c15be85 DHCP Sending DHCP discover (eth0)
3c15be85 DHCP Extensions present: 61 53 55 57
3c15be86 DHCP Sending DHCP discover (eth0)
3c15be86 DHCP Extensions present: 61 53 55 57
3c15be87 DHCP Sending DHCP discover (eth0)
3c15be87 DHCP Extensions present: 61 53 55 57
Blk Infiniti I-30, 1 OVR 0 MkII Serial # 080000457, 120gigs +2000 Music Cd's [Listing avail]
