Is this something to worry about? I ran the
fsck -fay / and
fsck -fay /drive0 commands without error, but I get the following message when running
fsck -far /drive1
empeg:/empeg/bin# fsck -fay /drive1
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /drive1 is mounted.
fsck.ext2: Is a directory while trying to open /drive1
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193
empeg:/empeg/bin#
I can see and browse through /drive1 through http/ftp and command prompt. Is there a problem with the partition if the filesystem check is giving me this message?
