If you when you do a search for for instance Titel press the Select Mode button on the remote, the mode will cycle between Insert, Append and Replace.
Insert: Inserts search result after current song, or if you already have something Inserted, just after the last item you previously Inserted
Append: adds search result to the end of the current playlist. It does not add itself to the playlist as generated by emplode but only to the current running order.
Replace: drop current playlist and use search result for new playlist
Read more here
/Michael
/Michael
