#80597 - 21/05/2002 03:01
Re: Things I Hate, Part II
[Re: svferris]
Your average joe doesn't get mad about em-dashes and en-dashes.
Well, he should! Correctly typeset text is a right of the reader, not a privilege.
For the record, all horizontal lines in the middle of bits of text are not created equal. There are at least four kinds.
A hyphen is used to connect two or more words into one, where ambiguity would result were they separate: a "sub-aqua club" rather than a "sub aqua club".
An en rule (&endash; in HTML, often represented as two hyphens where unavailable) is used for ranges: 4--12 megabytes per song. It's also used, with spaces each side, as a parenthetical separator -- rather in this manner.
An em rule (&emdash; or three hyphens) is used without spaces as a parenthetical separator---or occasionally to indicate direct speech---but is slightly old-fashioned these days.
The minus sign of mathematics is different again, typically longer than a hyphen but shorter than an en rule.
As for quote marks, it's more complicated still. The only quote-like characters in ASCII are the ' and " characters. Those are known as "unsexed" quotes (because they don't slant one way or the other) and are incorrect in typeset text except when used for the units of feet (or minutes) and inches (or seconds).
Whether for quotation of direct speech, or for scare quotes like those around "unsexed" above, the correct double quotes to use in typeset English text (other European languages are different) are the "66-like" and "99-like" ones available in HTML as “ and ” -- I don't have a Unicode spec handy to look up the exact character numbers. The correct single quotes to use are the "6-like" and "9-like" ones ‘ and ’. Apostrophe, the mark found in it's and similar words, is technically a different glyph from ’ but appears identical in all sane fonts.
The problem with all these sexed quotes is that they do not appear either in ASCII or in standard ISO8859-1. They appear in the reserved range (0x80-0x9F) of Microsoft code pages, and of Macintosh and Acorn encodings too -- but in three different places in those three encodings. That's why pages authored by Macintosh weenies sometimes look odd in Windows browsers (and vice versa): people have used the literal characters (unportable) rather than the entities (portable). The characters do not appear on standard keyboards (even French keyboards do not have the guillemet characters labelled).
Unix zealots tend to represent ‘ with grave accent and ’ with ', which looks wrong in almost all fonts these days.
This has been quite a long post already, so I'll stop ranting now, but I also hate people who think they can set text in small caps by using normal capitals in a smaller point size. Penguin Books do this on their spines these days. Penguin Books, for whom Jan Schichold once worked. How are the mighty fallen.
sancho
14/03/2002 12:59
grgcombs
13/03/2002 21:17
davec
14/03/2002 06:53
genixia
14/03/2002 14:55
genixia
15/03/2002 08:45
Whitey
15/03/2002 16:13
JeffS
16/03/2002 06:41
cyberco
14/03/2002 01:46
fusto
14/03/2002 12:16
Laura
14/03/2002 16:43
beaker
20/03/2002 10:25
ninti
17/03/2002 02:48
Whitey
17/03/2002 07:45
mtempsch
17/03/2002 08:26
Whitey
17/03/2002 08:56
Whitey
17/03/2002 23:39
svferris
18/03/2002 01:05
JeffS
21/03/2002 14:41
JeffS
21/03/2002 15:49
suomi35
22/03/2002 19:45
tracerbullet
23/03/2002 08:43
BleachLPB
27/03/2002 10:44
genixia
27/03/2002 10:54
BleachLPB
27/03/2002 10:57
genixia
27/03/2002 11:01
eternalsun
28/03/2002 11:17
eternalsun
28/03/2002 11:53
muzza
28/03/2002 21:30
eternalsun
29/03/2002 17:33
guardian__J
27/03/2002 11:06
genixia
27/03/2002 11:08
guardian__J
27/03/2002 11:12
muzza
27/03/2002 19:52
Satan_X
27/03/2002 21:59
svferris
27/03/2002 23:35
BAKup
27/03/2002 13:00
Laura
28/03/2002 05:15
guardian__J
28/03/2002 08:37
eternalsun
28/03/2002 11:13
Legoverse
04/05/2002 13:08
muzza
04/05/2002 16:15
genixia
04/05/2002 17:43
Satan_X
04/05/2002 22:25
Heather
05/05/2002 09:45
BAKup
05/05/2002 10:02
acurasquirrel_
05/05/2002 10:26
BAKup
05/05/2002 12:02
puckalicious
06/05/2002 06:00
Whitey
06/05/2002 09:58
matthew_k
06/05/2002 10:41
Whitey
06/05/2002 13:52
genixia
06/05/2002 14:02
Whitey
06/05/2002 14:12
dodgecowboy
06/05/2002 11:20
muzza
03/04/2002 20:55
BleachLPB
04/04/2002 11:14
muzza
04/04/2002 15:18
lectric
04/04/2002 16:03
muzza
04/04/2002 16:06
Laura
04/04/2002 16:26
Laura
04/04/2002 16:43
muzza
04/04/2002 19:08
Laura
04/04/2002 20:04
lopan
09/04/2002 20:29
ninti
09/04/2002 22:40
svferris
10/04/2002 16:01
Laura
10/04/2002 17:42
svferris
10/04/2002 20:57
JeffS
10/04/2002 04:14
lopan
10/04/2002 06:25
visuvius
03/05/2002 17:37
David
17/05/2002 07:23
svferris
20/05/2002 16:42
David
21/05/2002 02:28
svferris
20/05/2002 14:14
David
21/05/2002 02:39
genixia
21/05/2002 07:02
rob
22/05/2002 07:13
