#102570 - 02/07/2002 05:52 Please answer audio out question...
VeeDubDriver
Loc: Deerfield Beach, FL
The user manual specifications section under Audio Outputs says, "4V line level front & rear stereo phono (RCA) line jacks, 1V stereo phono (RCA) line jacks on chassis."
Now, my question is, when I hook it up to the RCA inputs on my headunit, is the output from the Rio Car 1V or 4V?
#102571 - 02/07/2002 08:10 Re: Please answer audio out question... [Re: VeeDubDriver]
Greetings!
If you are going from the bare empeg / RioCar, 1V. If you are hooking up the car sled wiring to your home system, 4V.
#102572 - 02/07/2002 08:12 Re: Please answer audio out question... [Re: pgrzelak]
VeeDubDriver
Thanks for the reply. Can you tell me why there is a difference between the two?
#102573 - 02/07/2002 08:32 Re: Please answer audio out question... [Re: VeeDubDriver]
Greetings!
Basically, the design was for audiophile use. The 4V outputs in the car can give a much better signal to noise ratio. The 1V is more standard for home stereo components. There is a little more info in The FAQ.
#102574 - 02/07/2002 08:40 Re: Please answer audio out question... [Re: pgrzelak]
VeeDubDriver
Thanks!
