#111334 - 16/08/2002 18:45 signs of a dying hdd cable?
Loc: Los Angeles, CA
ok, the most peculiar thing...
i start my car w/ the empeg in the bay... it starts to play a song, and after 5 seconds, sputters then stops. i say wtf, so i pull it out and put it back in.... it gives me a "no hd found, contact support" screen. then i pull it out, wait 5 minutes, put it back in, and switch songs as soon as i can. it then plays the next 2 songs properly.....
on the 3rd song.... it plays the song... and then a part of it gets garbled, then goes back to normal.. i rewind it to the same part, and its plays back ok now... 20 seconds later, the same thing....
is it time to email david for support?
#111335 - 16/08/2002 19:14 Re: signs of a dying hdd cable? [Re: image]
either the cable or the drive going bad. mine did that because one the the drives didn't have spacers under it.
#111336 - 17/08/2002 07:29 Re: signs of a dying hdd cable? [Re: msaeger]
i left it overnight to run.... and attached a serial cable to log what happens... heres what it did.
serial_notify_thread.cpp: 180:@@ #6780 0:06:08
serial_notify_thread.cpp: 180:@@ #6780 0:06:09
serial_notify_thread.cpp: 180:@@ #6780 0:06:10
hda: status error: status=0x58
hda: drive not ready for command
hda: read_intr: status=0x59
hda: read_intr: error=0x0c
serial_notify_thread.cpp: 180:@@ #6780 0:06:11
serial_notify_thread.cpp: 180:@@ #6780 0:06:12
serial_notify_thread.cpp: 180:@@ #6780 0:06:13
serial_notify_thread.cpp: 180:@@ #6780 0:08:09
serial_notify_thread.cpp: 180:@@ #6780 0:08:10
serial_notify_thread.cpp: 170:@@ S0
attempt to access beyond end of device
03:05: rw=0, want=2106931, limit=16569
dev 03:05 blksize=1024 blocknr=2106930 sector=4213860 size=1024 count=1
03:05: rw=0, want=2106916, limit=16569
dev 03:05 blksize=1024 blocknr=2106915 sector=4213830 size=1024 count=1
03:05: rw=0, want=2106917, limit=16569
dev 03:05 blksize=1024 blocknr=2106916 sector=4213832 size=1024 count=1
init(1): memory violation at pc=0xc00d87f4, lr=0xc0019730 (bad address=0x0200712
4, code 2)
pc : [<c00d87f4>] lr : [<c0019730>]
sp : c017bf38 ip : c017bef4 fp : c017bf84
r10: 00000002 r9 : c0fad060 r8 : 0000000c
r7 : 00000000 r6 : 02007120 r5 : bffffd9c r4 : bffffd84
r3 : 60000013 r2 : c00f61e4 r1 : 00000001 r0 : bffffd74
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Control: C0FA917D Table: C0FA917D DAC: 00000015
Function entered at [<c00117ac>] from [<c0012098>]
r10 = BFFFFE98 r9 = 00000000 r8 = C017BFD4 r7 = FFFFFFFF
r6 = 20000010 r5 = 02007154 r4 = C00F4978 Function entered at [<c0012080>] fr
om [<c0009fd4>]
Unable to handle kernel paging request at virtual address 02007124
*pgd = c0fa7801, *pmd = c0fa7801, *pte = 00000000, *ppte = 00000000Internal erro
r: Oops: 2
CPU: 0
Process init (pid: 1, stackpage=c017b000)
Stack: c017bf20: c0019730 c00d87f4 60000013 ffffffff c0fad078
c0fac0e0 c017bf40: c017a000 c017bf98 02007154 c0011b7c 02007140 02007154 0000000
2 c00f4978 c017bf60: 02007154 20000010 ffffffff c017bfd4 00000000 bffffe98 c017b
f94 c017bf88 c017bf80: c0012098 c00117b8 00000000 c017bf98 c0009fd4 c001208c 000
0000a bffffda8 c017bfa0: 00000000 00000000 bffffda8 00000009 0202ed90 bffffdac 0
203d938 00000000 c017bfc0: bffffe98 bffffd84 bffffd88 bffffd78 02007140 02007154
20000010 ffffffff c017bfe0: c0009ad4 c011d6dc c00f475c c00f4760 c00f3fd8 c017c0
00 c000b64c c0009ae0 Backtrace: Function entered at [<c00117ac>] from [<c0012098
om [<c0009fd4>]
Code: ebfd034a e2440010 (e5961004) e1a035a1 e59f20cc
Edited by iMaGe (17/08/2002 07:42)
#111337 - 17/08/2002 07:39 Re: signs of a dying hdd cable? [Re: image]
and the subsequent attempt to reboot:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v291 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Wed Jul 31 10:10:42 EDT 2002
empeg-car player (hardware revision 9, serial number 30102411)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9a38c
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:6
b
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#111338 - 17/08/2002 10:01 Re: signs of a dying hdd cable? [Re: image]
David
Loc: Cambridge
If it is a Rio-branded player, then it is most likely just a bad cable.
#111339 - 17/08/2002 11:14 Re: signs of a dying hdd cable? [Re: David]
yeah, it is rio branded. i've emailed you david at david@empeg.com (hope thats still the right one to send to. hope to hear from you soon.
