#123211 - 26/10/2002 09:32 Haveing problems
haffi
Loc: Iceland
sometime my player just Frezzes while the "W" is in the corner window. I reboot it and it says there is no hardisk then I try few times and after a while it will go back on.
Hard disk is new IBM 40 gb. when I got to serial this is what it does when
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v292 (root@tbird.localnet) (gcc version 2.95.3 20010315 (release)) #2 Wed Aug 28 11:59:43 EDT 2002
empeg-car player (hardware revision 9, serial number 40103343)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9a38c
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N040ATCS04-0, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0d:0f
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5change_root: old root has d_count=1
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Comp
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
hda: lost interrupt
Can anyone tell me what this could mean? the cables are fine I checked them yesterday.
Hafr Hilmarsson
CCIE VOICE #24527
Iceland.
#123212 - 26/10/2002 09:39 Re: Haveing problems [Re: haffi]
It could mean that your hard drive is going bad, or it could mean that the IDE cable is bad. There's a known manufacturing defect with some of the IDE cables that were sent out that's not visible. So if you haven't already gotten it replaced, contact support about it.
#123213 - 26/10/2002 22:02 Re: Haveing problems [Re: haffi]
Haffi, this is a FAQ entry. Please click here.
