Not neccessarily - FM and AM are far enough apart for them to be affected differently. You might have a capacitive 'short' somewhere that attenuates higher frequencies (FM) more that lower frequencies (AM). Or the connection could be such that it's appearing as an inductance, which would have the same effect.
Anyway, theories aside, in any electronic component, bet on mechanical elements failing first. In this case, the connector.
