Welp, on top of that.... i put it all back together, and it's doing what it did before. (i failed to mention this in the first post). It just boots up to the Hijack Penguin and sits there. You can use the hijack menu but the player never starts. *sigh* off to Hyperland....
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v296 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Thu Sep 26 00:04:46 EDT 2002
empeg-car player (hardware revision 9, serial number 10102077)
Command line: mem=16m
Memory: 15084k/16M available (924k code, 20k reserved, 352k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:1
d
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
It's not seeing the drives. Nurse, screwdriver STAT!
