#132996 - 03/01/2003 21:38 mounting windows network folders
RobotCaleb
for a lan im helping a guy configure weve got a 180gb file server running win xp pro. i would like to be able to access that using my linux webserver. afai can tell, samba is used only for doing the opposite of what i want. how do i mount a directory on the fileserver from linux. (xp is ntfs, right?)
ie. 'mount -t ntfs 192.168.1.123\shared_folder /home/customsex/fileserver' is what i would want to happen, but i know thats not how to do it. just a way of showing what i want better, i guess. any help would be greatly appreciated.
#132997 - 03/01/2003 21:56 Re: mounting windows network folders [Re: RobotCaleb]
ricin
Loc: US: CA
Samba is what you want, it can do exactly that as well.
Take a look here for details.
Basically, it would be:
mount -t smbfs -o username=USER,password=PASS //server/share /path/to/mount-point
Of course, you can leave out the -o and accompanying switches if you don't need a username and password.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#132998 - 03/01/2003 22:24 Re: mounting windows network folders [Re: ricin]
RobotCaleb
thanks for the quick response. another question. when i only have one nic in my linux box it performs as desired and as expected. its got an ip that is not a local, which is good. now, i also run a counter-strike server on this box. i thought it would be a good idea to throw another nic in and have it run on the lan also. that way people dont have to search for the server in the long list of internet servers, it would just pop up under lan servers. i plug in the new nic, configure it. it grabs an ip from my dhcp server, and the outside ip stops working. people from the outside cant connect to the box anymore. a quick check shows that all internet traffic is now routed through the lan, which doesnt work for me. is there something i need to do that will specify to only use eth1(eth1 being the newly added nic) for local traffic?
#132999 - 03/01/2003 22:48 Re: mounting windows network folders [Re: RobotCaleb]
ricin
Loc: US: CA
That would be routing. You'll need to change your default route back to eth0 and add a route for the local network, routed through eth1. Post the output of "route" and lets see what you have now.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#133000 - 03/01/2003 23:08 Re: mounting windows network folders [Re: ricin]
RobotCaleb
[root@63 root]# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
63.166.59.112 * 255.255.255.240 U 0 0 0 eth0
192.168.1.0 * 255.255.255.0 U 0 0 0 eth1
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth1
default 0.0.0.0 UG 0 0 0 eth0
can i change the routing easily in linuxconf?
#133001 - 03/01/2003 23:34 Re: mounting windows network folders [Re: RobotCaleb]
ricin
Loc: US: CA
Yes, you can do it in Linuxconf. It is under Networking > Client Tasks > Routing and gateways. You'll want to set the default route to the eth0 card, and set a route to your local (192.168.1.x) network. Linuxconf might get confused, though.
You have two default routes at the moment, and that just doesn't work
You can remove the default route to 192.168.1.1 by doing:
route del default 192.168.1.1 eth1
Then add the route, with gateway, to your local network, through eth1:
route add -net 192.168.1.0 netmask 255.255.255.0 gw 192.168.1.1 eth1
All should be well after that.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#133002 - 04/01/2003 00:13 Re: mounting windows network folders [Re: ricin]
RobotCaleb
thanks. seems to be working. but only time will tell. now to play with the samba
#133003 - 04/01/2003 04:33 Re: mounting windows network folders [Re: RobotCaleb]
ricin
Loc: US: CA
No problem. You can PayPal me $20.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#133004 - 04/01/2003 15:35 Re: mounting windows network folders [Re: ricin]
RobotCaleb
heh
