Is this W2K or XP? Can you log on as a different user & check if OE still crashes when launched? If it's a fault in the data files as opposed the program's this test might indicate that. Have you tried installing/reinstalling IE 6 (comes with OE bundled), as opposed to just OE? If you're done with it, I can respect that. Remember Outlook (the non-Express version) should be able to import your OE messages & email settings, assuming your data files aren't hosed.
I've noticed much less strange behavior from Outlook than OE, FWIW.
-Zeke
WWFSMD?
