I've just upgraded one of my drives and the player now rebuilds the music database on every boot.
In Hyperterminal, entering 'q' followed by 'exit' causes a rebuild too. Here is a snippet from Hyperterminal:
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4054d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 9735
98, error=0xc0044000
Previously the player was 20GB(hda) + 30GB(hdb), I have upgraded the 20GB to a 40GB so it's now 40GB(hda) + 30GB(hdb).
I used the
drive upgrade faq and in particular Step 7 (Copying files) to move the music across to the new 40GB and everything seemed to go ok.
Pressing Down, Down, Down queues 5325 songs (about right) and it plays ok.
I have tried
deleting the database but the directory /empeg/var is always empty.
Emplode won't initialise properly, it get's stuck at 'Checking Media' with the following appearing in Hyperterminal:
Adding Swap: 16028k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
hdc4 is mounted.
I'm kindof stuck, any ideas please?
