Ok,I'd do my own research, but my ADSL net connection has been the shits all weekend (note, not to be confused with "the s
hit"). I can connect fine peer-to-peer and IM, but a large number of websites can't be accessed and an even larger prcrentage just load far too slowly (eventually timing out, etc...) For reference, if anyone is in Canada, stay away from AEI.ca (http://www.aei.ca) - $30 per month unlimited ADSL, but far too frequently goes down completely or this happens.
Since I can't access google right now, here are some questions:
Photoshop: Has anyone else tried using it with an Extended desktop in Windows XP? When putting its window or palettes on the extended desktop (secondary monitor or TV), they don't redraw. Plus, clicking on any element in a palette on the extended desktop causes that palette to pop back to the primary monitor. If this is normal for Photoshop then a big "boo" to Adobe. Get with the program. If this isn't normal then I'm going to have to kick someone's ass at work to fix our drivers.
Does anyone know of any programs or hacks to allow me to put a background picture on the secondary (extended) display that is different from the one on the primary display? It looks completely stupid having the same picture repeat which is default. Not to mention that the one on the secondary display does not shrink to fit that dsplay's resolution (it uses the prmry display's resolution and just shows you whatever is visible within the screen res for that display (ie. 1024 on primary and 800x600 on secondary showing the middle portion of the primary picture).
Thanks for any help. Trying my hardest keeping it off topic.
