#148431 - 13/03/2003 04:45 USB wireless Adapter.
haffi
Loc: Iceland
This has probly been asked before but I saw no answers .
Is the anyway to compile a driver for some USBwireless adapter either 802.11b or the 54 mb one. into the kernel ?
? or does the usb port not work for that kind of stuff ? I mean is it set into slave mode only ?
since I never use it I figured why not try to put a USB-Wireless NIC on it
Edited by haffi (13/03/2003 04:48)
Hafþór Hilmarsson
CCIE VOICE #24527
Iceland.
#148432 - 13/03/2003 05:06 Re: USB wireless Adapter. [Re: haffi]
Yes. The USB port on the empeg is a slave port. Plugging a USB ethernet adapter into it would be very difficult, if not impossible.
An alternative is to use a wireless/ethernet converter (e.g. the Linksys WET11) to connect the empeg to your wireless AP.
#148433 - 14/03/2003 17:59 Re: USB wireless Adapter. [Re: Roger]
smu
Loc: Germany (Ruhrgebiet)
Oh, by the way:
If you don't need the device to be really small, I would recommend using the WAP11 instead.
  1. It is cheaper than the WET11, and
  2. it is more flexible, since you can also use it as a bridge (which you need if you want to use a laptop in your car once in a while (wired to the "car network" which is connected through the WAP11 in the house).
  3. The WAP11 can be updated to run at 22MBit instead of 11 if your flash a D-Link software to it instead of the LinkSys software. This also enables you to increase the antenna power level.
Don't know wether the last point also holds true for the WET 11 as well..
cu,
sven
#148434 - 14/03/2003 18:29 Re: USB wireless Adapter. [Re: smu]
Daria
Isn't the 22mbps stuff by flash upgrade only supported on the newer WAP11s? I thought the older hardware simply wasn't capable of it.
#148435 - 15/03/2003 02:46 Re: USB wireless Adapter. [Re: smu]
ricin
Loc: US: CA
b. it is more flexible, since you can also use it as a bridge (which you need if you want to use a laptop in your car once in a while (wired to the "car network" which is connected through the WAP11 in the house).
The WET11 is actually a bridge, and can be used in the same manner. Of course, you would need a hub/switch to have the empeg and the laptop plugged in at the same time.
I completely agree with you on going with a WAP11 instead, though.
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#148436 - 19/03/2003 08:51 Re: USB wireless Adapter. [Re: ricin]
rowitech
Loc: Germany, Cologne
I've seen a Bluetooth-Access-Point from http://www.tecom.com.tw which provides an USB-Master to drive a printer. Maybe it would be possible to get this thing working with the empeg's USB-Slave. But this could be much more complicated than plugging into the ethernet-port. Just an idea.
Rolf
Connecting Empeg via Bluetooth or Wireless LAN http://empeg.rowi.net
*** Proud owner of the European Worst Install Trophy 2003 ! ***
RoWi
