#148659 - 14/03/2003 23:17 XP NTFS question..
durden
Loc: Texas
Is there a 130ish GB limit to formatting an NTFS drive when using XP (booting off the cd and installing XP on a new drive that hasnt been formatted)? I have noticed twice now on two different machines where I have put in 180gb drives and only been able to format 130gb of them, when I try to format it using the windows XP (pro) installation format utility. The first time it happened, I wrote it off as an old Bios / motherboard that couldnt support it.. But it turned out that we were able to format another 180gb drive in that machinewith no problem, *after* windows was installed (using windows disk management utility, or whatever its called)
But now, I have a brand new system, Intel E7205 chipset, and I seriously doubt there is a bios limitation going on here..
What's the word on this? I can't find info anywhere..
- durden -
#148660 - 15/03/2003 01:35 Re: XP NTFS question.. [Re: durden]
Happy Birthday StigOE
XP has a limit of 137Gb unless you do some registry hacking, which might be a bit difficult during installation.... Do a search on the M$ site or on this BBS for 137Gb and you will find the registry hack. After XP is installed you could use Partition Magic to increase the partition.
Stig
#148661 - 15/03/2003 06:03 Re: XP NTFS question.. [Re: durden]
Glen_L
Loc: Elk Grove, CA
No longer a stranger, finally a full-fledged member! \:D
#148662 - 15/03/2003 10:42 Re: XP NTFS question.. [Re: Glen_L]
durden
Loc: Texas
Yeah, I figured I would give XP SP1 a chance and see if it would work after I made the post; and sure enough it sees the "full" drive. I guess I can live with 2 partitions :P Thanks for the info!
- durden -
#148663 - 15/03/2003 23:07 Re: XP NTFS question.. [Re: durden]
You can "slipstream" an XP CD to SP1, so that it will be able to format the entire drive at initial boot. Complete instructions are here.
#148664 - 15/03/2003 23:59 Re: XP NTFS question.. [Re: drakino]
durden
Loc: Texas
Very useful. Much obliged!
- durden -
