#153008 - 03/04/2003 15:11 Support... how?
amthar
Loc: North Carolina
I am trying to get my screen replaced/functional. The fill nipple is intact and I couldn't see any obvious fuses blown on the board. I emailed 'carsupport@sonicblue.com' a week ago and have not heard back. How do I get this thing fixed? Thanks.
#153009 - 03/04/2003 15:47 Re: Support... how? [Re: amthar]
oliver
the fuses will not look burnt, or broken. The fuses are very small, and only a voltage meter will tell you if the fuse is blown. I had 1 fuse blow in my empeg.
This was the fuse that blew in my empeg
#153010 - 03/04/2003 16:09 Re: Support... how? [Re: amthar]
You'll have to be patient I'm afraid. RobV said the other day that RobS is a bit behind on his support email at the moment and is planning to catch up on it sometime this week.
#153011 - 03/04/2003 17:16 Re: Support... how? [Re: oliver]
foxtrot_xray
Loc: Atlanta, Georgia
Wow.. an SMT fuse..
Aargh. I hate SMT. Can't do easy work on them like thru-hole.
Me.
#153012 - 03/04/2003 18:59 Re: Support... how? [Re: foxtrot_xray]
genixia
Actually, standard pitch surface mount can be easier to deal with than PTH. Needs slightly different mind-, skill- and tool- sets, but removing solder and cleaning pads after a component removal is incredibly easy compared to PTH.
Obviously as the size goes down and lead count goes up, everything gets harder. But I'd hazard a guess that dealing with a 84 pin 0.5mm surface mount chip would still be easier than dealing with an 84 pin 0.5mm PTH chip (if such a thing existed).
#153013 - 03/04/2003 19:14 Re: Support... how? [Re: genixia]
maczrool
Loc: Louisiana, USA
A product called Chip Quik makes SMD rework very easy, with minimal equipment and effort. Give it a try. You can get a kit for about $15.00.
Stu
#153014 - 04/04/2003 19:51 Re: Support... how? [Re: genixia]
foxtrot_xray
It's that whole mind-set thing I have a problem with.. Havining none, I can't change it easily.
Me.
