#163025 - 27/05/2003 19:03 Tuner muting
muzza
I seem to be having a problem with the tuner mutes momentarily when the AF function or RDS info is recieved. It only does this with one station here (JJJ) so i suspect the RDS.
this has only started with the 2.0 final upgrade
Is anyone else having this?
#163026 - 27/05/2003 20:46 Re: Tuner muting [Re: muzza]
Hi Muzza
I don't have it muting exactly. Mine is more a glitch (almost a skip if you will) when the RDS-AF stuff tries the other frequencies to see if they are stronger.
I'm guessing this is on 107.7?
Unfortunately though you can't turn AF off (due to a bug which appeared in 2.0final) which makes JJJ almost unlistenable for me because of the glitches.
The way I understand it though the RDS-AF feature of testing other frequencies for signal strength shouldn't intrude and shouldn't be audible. In that case I believe it's not doing this correctly either.
#163027 - 28/05/2003 23:29 Re: Tuner muting [Re: Shonky]
muzza
Yes this is what it's doing. It's more of a slight drop-out as it scans the other frequencies.
Oh well, I'll have to wait for 2.01
#163028 - 03/06/2003 07:59 Re: Tuner muting [Re: muzza]
Warp10
Loc: Germany
Hi! I've got excactly the same problems. It only happens with stations broadcasting RDS signals. Since I live in Germany, nearly every station broadcasts RDS, so listening to the radio is quite frustrating... cheers
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
