#169804 - 09/07/2003 14:45 Samba help
eliceo
I am trying to setup a share on a redhat machine, that can be read by windows machines. I have tried to setup samba and the share correctly but I think my inexperience with linux has got me stuck. Does anyone know of some links that can explain the use of samba, or someone who can kindly explain what i need to do to get a share working and visible. I can ping the machine, but trying to access with \\ ip address\ wont work.
#169805 - 09/07/2003 15:01 Re: Samba help [Re: eliceo]
Did you read this?
The Unofficial Samba HOWTO
#169806 - 09/07/2003 15:03 Re: Samba help [Re: eliceo]
cushman
Loc: Erie, CO
Get swat up and running, and your life will be happy again. It gives you a control panel for Samba via a webpage. See the man page for swat for more info. Then point your web browser at http://yourmachine:901/ to access swat.
Mark Cushman
#169807 - 09/07/2003 15:07 Re: Samba help [Re: cushman]
Yeah, more things to go wrong. Great. I've never found swat to be good for initial setup, and I find it to be pointless for config changes.
I'd say ignore swat altogether and just read the documentation.
#169808 - 09/07/2003 15:19 Re: Samba help [Re: wfaulk]
cushman
Loc: Erie, CO
I just find it faster for me, since I can configure it on the fly from the target machine (usually windows). I thought it was quite simple and easy to use.
Mark Cushman
#169809 - 09/07/2003 15:47 Re: Samba help [Re: eliceo]
muzza
Are you able to use [url=http://www.webmin.com/]webmin[/url}?
I've found it easy to set up things in linux in general. There are a few tricks for samba, but it has all the parameters there.
#169810 - 09/07/2003 16:03 Re: Samba help [Re: eliceo]
Being that it is a RedHat machine, how is the firewall configured? I know every recent version has had a Firewall on by default during install. Not sure how to turn it off though, as all my installs have been on test networks where I simply disable it during install.
#169811 - 09/07/2003 16:11 Re: Samba help [Re: drakino]
eliceo
in 'setup' I choose no firewall, but everytime i run 'setup' it seems to reset to high.
#169812 - 09/07/2003 17:11 Re: Samba help [Re: drakino]
ricin
Loc: US: CA
Lokkit ('lokkit or 'redhat-config-securitylevel') sets up iptables in RH. You'll want to check what's currently in there ('iptables -L'), and depending on how secure you want it to remain, either add a rule for Samba or remove everything ('iptables -F'). You'll want to check /etc/sysconfig/iptables as well, and clear it out if you're deleting everything.
See here for more info.
ricin
MkII/080000565
MkIIa/010101253
ricin.io
#169813 - 09/07/2003 17:16 Re: Samba help [Re: drakino]
God, I hate RedHat. It's turning into Microsoft -- I know what it is you want to do and how to do it! Bastards.
#169814 - 09/07/2003 17:18 Re: Samba help [Re: wfaulk]
ricin
Loc: US: CA
Yep, I can't stand it either. Unfortunately, it's a standard at my company, so I'm forced to use it. (Except on my workstation, I've got Gentoo there. )
ricin
MkII/080000565
MkIIa/010101253
ricin.io
#169815 - 10/07/2003 12:33 Thanks [Re: ricin]
eliceo
Thanks to everyone for the responses, finally got the stupid thing working. The knowlege of the people on this board is pretty wide.
