#170464 - 14/07/2003 07:13 Equalizer settings for different sources
Warp10
Loc: Germany
Hi!
Is it possible to have different EQ settings for each source?
If I switch to radio, for example, the sound has to much bass.
cheers,
thorsten
Edited by Warp10 (14/07/2003 12:39)
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
#170465 - 14/07/2003 13:58 Re: Equalizer settings for different sources [Re: Warp10]
bodybag
Loc: Southern California
I wanted to have this option too. Mentioned it a while back in a different thread. It didn't get much discussion beyond just my initial comments, but I wonder if it could be controlled via Hijack or if would have to be in the player software? Anyway, maybe we should add it to the wish list?
Bodybag - So Cal
Not a Whiner any more!!!
#170466 - 14/07/2003 14:16 Re: Equalizer settings for different sources [Re: bodybag]
durden
Loc: Texas
Yeah, that is something that I really wish could be done as well. If they could figure out why my tuner reception sucks so bad, that would be great too!
- durden -
#170467 - 14/07/2003 14:37 Re: Equalizer settings for different sources [Re: bodybag]
Warp10
Loc: Germany
I've browsed through the FAQ and found the following:
http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index&myfaq=yes&id_cat=11&faqent=182#182
Note the following two options:
-volume_boost_FM=nnn
-disable_bassboost_FM=1
That's exactly what I was searching for!!! Praise the FAQ!
#170468 - 14/07/2003 14:43 Re: Equalizer settings for different sources [Re: durden]
Warp10
Loc: Germany
Why excactly does your reception suck? I mean, do you have a bad reception in general, or does it only sound crappy while listening to stations broadcasting extra information, e.g. RDS? Which software version do you use? Is the tuner from patrick?
I had the problem that my reception was always bad while listening to RDS stations. It sounded choppy. I downgraded from 2.0 final to 2.0 Beta 13 and the problems went away!
#170469 - 14/07/2003 14:58 Re: Equalizer settings for different sources [Re: Warp10]
durden
Loc: Texas
It pretty much sucks in general... Unless I am REALLY close to a station, the reception will typically come and go quite frequently. Its quite possible that this is just because of my particular antenna, but I honestly think I had better reception in my old car WITHOUT an antenna. Yes, this is one of patricks ones. I might try downgrading too, just for kicks.
- durden -
