A wish: to have the player software listen on a socket, so that an application can connect over the network and send commands (similar to those on the serial port) to control the player.I only have a Mark 1 (i.e., no ethernet), but... Doesn't the "play" button in Emplode work when you're using ethernet?
If so, then this capability already exists and all you've gotta do is work out the protocols. Let us know when you have the app written. I expect it by next Monday.
Another option (assuming what I just said works) is to just use Emplode as your remote-control application. All the playlists are there and you can select them and play them to your heart's content.
