I think this is very basic for someone who has some ecperience with Cisco Firewalls.
I have a Cisco PIX515 and I want to set both it's "inside" and "outside" ethernet interfaces to 100 HALF duplex. I have all the passwords. What commands should I use?
On the switches I used to manage I did this:
config t
int fastethernet 0/1
speed 100
duplex half
<CTRL-Z>
write mem
done.
With the 515 PIX I can't get that far. I enter the config mode:
config t
then I see, by using "show int" that both the ethernet0 and ethernet1 interfaces are set to 100 full duplex. What should I do? "speed" and "duplex" commands are not available.
Thank you in advance...
