Neat pix. Since you've got a tape, a changer, and the empeg, you basically have all the music you can stand now, huh?
Since you're still using separate amps, which way did you end up wiring it? Empeg first in the chain or last in the chain?
Also- I noticed something that I've seen in some other install pix:
Was there any way to avoid that gap being visible in your installation? On my Honda, I had to cut a piece of black plastic to go around the front of the sleeve to cover it up.
I'm wondering how common this is.
