#179814 - 18/09/2003 02:22 What software do you use to stream from your Empeg
LTJBukem
Hi,
What software do you use to stream from your empeg ?
I used to use WInamp 2, although i found this somewhat unreliable, as sometimes there were breaks in the stream, or a total loss of connection.
I want to leave my Empeg in the Mlord Docking Station downstairs in the hi-fi rack, and stream music via ethernet to the PC upstairs. It would need to be simple so that SWMBO could use it. I don't have a very good computer (433 w 256mb),and it doesn't have the HD space to store all the tunes.
Generally I use WMP 9, so it would be great if there was a way of using WMP 9 to stream the tunes. Otherwise i'm open to ideas.
I also have PCDJ which grreat for mixing MP3s but i'm sure it's a pipe dream to be able to stream these of the empeg straight through the computer.
Any advise very welcome.!
LTJ
#179815 - 19/09/2003 02:45 Re: What software do you use to stream from your Empeg [Re: LTJBukem]
JaBZ
Loc: NZ
errr install winamp 3, I haven't had any issue with it works fine.
Jai
#179816 - 19/09/2003 09:33 Re: What software do you use to stream from your Empeg [Re: LTJBukem]
jarob10
Loc: Stockport, UK
Streaming via WMP9 works for me.
#179817 - 19/09/2003 09:58 Re: What software do you use to stream from your E [Re: LTJBukem]
Daria
I suppose if I said netcat you'd look at me, puzzled.
#179818 - 19/09/2003 10:03 Re: What software do you use to stream from your Empeg [Re: jarob10]
LTJBukem
How do you get it to work with WMP9 ?
LTJ
#179819 - 20/09/2003 01:17 Re: What software do you use to stream from your Empeg [Re: LTJBukem]
jarob10
Loc: Stockport, UK
associate a .m3u with WMP9, and itt should work I think. What operating system /' IE version are you running ?
#179820 - 21/09/2003 18:03 Re: What software do you use to stream from your Empeg [Re: JaBZ]
trs24
I was using WinAmp 3 but found the lack of features as compared to WinAmp 2 and buggyness annoying. So I switched to WinAmp 2.9 - which is actualy newer than WinAmp 3 - and it's worked great.
- trs
- trs
#179821 - 22/09/2003 18:53 Re: Ignore this -- testing an internet connection. [Re: trs24]
Happy Birthday tanstaafl.
This is just a test to see if my internet connection is running at a proper speed.
Sorry for the clutter...
#179822 - 23/09/2003 01:21 Re: Ignore this -- testing an internet connection. [Re: tanstaafl.]
I could probably find a web-ad or two with the solution to this.
Speaking of... have you considered using a tabbed browser?
