Hi.
I originally posted this as a question in "technical", but I think posting it as a wish is more appropriate. So here is my wish:
If it isn´t a hardware issue, please make empeg´s reaction on the different power sources configurable, so that one might connect the empeg to a home stereo using it´s for channel (car docking connector) output.
Here is the reasoning behind it:
My reason: I would like to use the four channel, 5 band each EQ of the empeg even when at home (along with the front/back-fader and the balance of course). I ordered a second car sled, but to be able to make use of empegs personalities and to make it connect to my LAN, I´m going to modify the sled accordingly.
Another reason: on the projects forum (AFAIR), someone posted a project (external DSP with sooundshaping) that would use the empegs outputs on stereo only, but is intended for in car use. He might make use of the empegs 2 channel, 10 band each EQ (though his external box will include an EQ, I guess usings the empegs EQ might be more convenient).
So how about a configuration option in empegs .ini-file like:
ACchannels=4
DCchannels=2
(or the other way round, or even both to 4(2) channels).
cu,
sven
