#187810 - 03/11/2003 10:33 Blaupunkt Sterring wheel remote...
beamer
Hi... i just got my hands on a Blaupunkt steering-wheel remote, which i ofcause would have used with my EMPEG.... BUT... it just doesn't seem to work!? .... when in button codes display, the EMPEG doesn't react.... what could be wrong ? ... the remote works, that i know...
- Regards from - Christian Byriel - Empeg MK2a
#187811 - 03/11/2003 10:36 Re: Blaupunkt Sterring wheel remote... [Re: beamer]
If I remember correctly, the Blau remotes use a different carrier frequency. The empeg will not see this remote. Can anyone confirm?
#187812 - 03/11/2003 10:40 Re: Blaupunkt Sterring wheel remote... [Re: pgrzelak]
beamer
Oh no... the remote is so cool.... oddly the EMPEG can't see my TV remote either...
#187813 - 03/11/2003 10:53 Re: Blaupunkt Sterring wheel remote... [Re: beamer]
Happy Birthday tonyc
Most or all of the Blaupunkt remotes use an incompatible carrier frequency. You should have done a quick BBS search before buying it. This thread documents other problems with people trying to use Blau remotes, for instance.
A good substitute would be the Pioneer CD-SR77 or CD-SR80. I use the SR77 with excellent results. Others are happy with the Kenwood steering wheel remote (not sure of the model number.)
#187814 - 03/11/2003 10:59 Re: Blaupunkt Sterring wheel remote... [Re: tonyc]
beamer
Well i didn't buy it, i borrowed it from a friend... i don't see the pioneer as an option as it's ugly and not very cool at all... way too big too....
#187815 - 03/11/2003 11:07 Re: Blaupunkt Sterring wheel remote... [Re: beamer]
Well good luck finding other options, then. If there is a "cooler" option out there, I sure haven't seen it, and I've been around here longer than most.
#187816 - 03/11/2003 11:42 Re: Blaupunkt Sterring wheel remote... [Re: beamer]
Your other options for steering wheel control are listed here, just so you know.
#187817 - 03/11/2003 15:17 Re: Blaupunkt Sterring wheel remote... [Re: tfabris]
beamer
Hm... well so much for that idea, don't like none of the other posibilities, so i'll keep using it as is...
#187818 - 12/11/2003 12:35 Re: Blaupunkt Sterring wheel remote... [Re: tfabris]
By the way, I just had my installation completed and I got a Pionner SR100 remote. It looks just like the other two you mentioned and I have no idea what the difference is in terms of features. I confirm it is really comfortable. I find it better than the kenwood steering remote (which however had the advantage of being invisible), and that's why I chose this.
As a side note, I actually am experiencing this problem: somtimes it stops working, and I still don't understand if it is Alpha3 causing this or the battery, which I have no idea how old it could be. I'll find out.
However, I originally wanted to install a Sony Stalk. My installer did not have a cable one, as those mentioned on the FAQ, so we tested two IR Sony remotes, one basically identical to the stalk in the FAQ and one shaped as a semi-sphere. Unfortunately, the empeg would not see them. So, surprisingly, Sony IR are not compatible with the empeg, either.
Edited by taym (12/11/2003 12:35)
#187819 - 13/11/2003 22:04 Re: Blaupunkt Sterring wheel remote... [Re: beamer]
Hmmm... Here's a great device frfom PAC that's suitable for in-car wired control devices... I'm searching now to see if they have any IR-IR remapping products. Running wires to a Thumber wouldn't be too practical while it's mounted to your steering wheel.
http://www.pac-audio.com/products/swi.htm
Another solution is to use a Sony Stalk - which requires the use of a tuner module for the empeg (I wonder if the SWI-X above could be hooked up for this... Anyone else come up with an alternate to the tuner?)
#187820 - 27/04/2004 06:03 Re: Blaupunkt Sterring wheel remote... [Re: Taym]
jules
Loc: Indiana USA
Taym, can you get the Empeg to recognize Long presses with your SR100? Do you ever get a single button-press generate more than one to the Empeg?
#187821 - 27/04/2004 07:57 Re: Blaupunkt Sterring wheel remote... [Re: jules]
I have uninstalled the SR 100 remote a while ago. I do remember that some buttons at least could not. Maybe none of the buttons could.
And yes, unfortunately I did get more than one presses instead of one, but I seem to remember it was only related to the top button.
Edited by taym (27/04/2004 08:00)
#187822 - 27/04/2004 10:48 Re: Blaupunkt Sterring wheel remote... [Re: Taym]
jules
Loc: Indiana USA
