Here are two patches that give Jemplode drag and drop from the tunes table to the playlists.
I disallowed the ability to copy entire playlists 'cos this could cause problems with recursion.
However you can select and drag and drop thousands of tunes.
The major problem is that if you have say 5 tunes selected the default behaviour is to clear the selection when you click on the 6th tune unless you hold down the control key. This can be a tad annoying if you want to copy a few distributed tracks and click on one of them to start the drag.
I'd prefer the selection to be set cleared on mouse-up not mouse-down.
Anyway - hope this is useful...
Please let me know if you don't like how I've done it - this is my first go at gui stuff under java (though I've done a bit of the other in my time
Also, I may have bypassed design approaches (eg the inzyme Containers etc) because I just haven't had time to read *all* the Jemplode source !!
David
PS Eclipse 3 has been a bit of a pain with libs - and you can't create patches between tagged versions - just local disk vs HEAD by the look of it.
