#189585 - 15/11/2003 05:31 IP Address weirdness
CrackersMcCheese
I started a basic forum over on www.all-forums.net for a local group and it seems that myself and other users have the same IP address of 62.252.128.7
Now am I missing something? How can we have the same ip address while on at the same time? We live 2 miles from one another with the same isp if that helps explain it.
Thats not even any of our ip addresses!!
It makes polls impossible.
#189586 - 15/11/2003 06:30 Re: IP Address weirdness [Re: CrackersMcCheese]
Because that's a transparent web cache. 62.252.128.7 is cache4-renf.server.ntli.net
#189587 - 15/11/2003 06:35 Re: IP Address weirdness [Re: tman]
CrackersMcCheese
I'm sorry, I don't know what that means!
Am I stuck with it?
#189588 - 15/11/2003 06:40 Re: IP Address weirdness [Re: CrackersMcCheese]
NTL have a machine between you and the internet caching web pages. It's to save bandwidth since chances are that you'll be accessing a lot of pages that other people have recently looked at. Since they'll be most likely the same, it can save a copy and then just give you that instead. Not sure how to bypass it though as I don't use NTL...
#189589 - 15/11/2003 06:47 Re: IP Address weirdness [Re: CrackersMcCheese]
Don't think there is much you can do apart from try and use another cache. It's only sidestepping the problem since you'll be stuck with another IP address. There's a page about it here.
#189590 - 15/11/2003 07:17 Re: IP Address weirdness [Re: tman]
CrackersMcCheese
Thanks for the info. I have changed the settings to allow only registered members to vote in polls. It now tracks User IDs as opposed to IP addresses
