hello,
i got my player to work (the power adapor was bad and radioshack had a pretty good new one for me!
I'm trying to complete my had drive upgrade but my hard (brand new one, just replaced) seems not to be detected as the player gives me the no harddrive found contact support message. i've read te FAQ but to no clear solution based on my knowledge.
the message i get from hypertermnal is the following:
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:4
b
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
what does this mean and how do i fix it?
please help,
Marco
