Oh, ok. Well if that's the case then I must have something set wrong in my config. If I force DC power mode and set up a terminal program to read at 4800 I get the following when I reboot.
J ,ǩ/,BO:jÔ9|*6
*;"Ct+ʭ+) +c㹇cmJ'} O
f(({)BnjK)kC/Jbjy BՑrate: 4800, disabling logging
The garbage at the beginning is the Linux startup data at 115200 then I see "rate: 4800, disabling logging"
This must be turning off the data output, how do I turn it back on? My config.ini is
[hijack]
suppress_notify=0
[output]
notify=1
