I want to backup the drive... What is the easiest method!If you want a genuine backup, the easiest way is to remove the drive from the Empeg and plug it into a PC. Then you can use whatever backup software you want. If it's a desktop PC, you'll need an adapter cable and an OS/Backup program which understands Linux partitions.
If you don't want to remove the drive from the Empeg to get the job done, it gets quite complicated. But for the most part, you don't need to do a backup unless you're trying to preserve song files that aren't kept anywhere else.
I highly recommend that you
do keep your song files somewhere else so you can avoid even
needing to back up the Empeg. Either leave the songs on your PC after you've uploaded them to the Empeg, or make sure to back them up before you delete them from your PC.
Aside from that, you don't need to back up the Empeg's drive because the software partition is completely wiped clean and rebuilt with every software upgrade. The music is kept on a separate partition from the player software and isn't easily damaged unless the hard disk fails.
Empeg doesn't offer a pre-made backup utility at the current time. If they did, then the Empeg would be classified as a music copier rather than a music player, and would need to be subject to the AHRA tax and would come under the scrutiny of the RIAA. This has been the subject of many heated discussions here on the BBS, something I don't think needs to be re-hashed now (since Empeg can't change this fact and it's out of their control).
Dionysus, would you mind doing a FAQ entry on the whole "copy music off the player" issue? I'd do it, but I'm afraid I wouldn't be objective about the subject since I have some pretty strong opinions on it.
