Hi,
I simply cannot figure this out.
The in car line-outs are 4V, the "home" line-outs are 1V. This means that in the car you can expect 4x (Hugo mentioned it was around 2x if you measure it with a voltmeter) the amount of sound coming out of the empeg compared to when hooked up at home.
Having several problems with my car setup, I did the following comparison:
The AC amplifier is set to a certain fixed volume. The empeg is set to 0 db volume adj.
Then I compare sound volume between:
Empeg on AC power, using "home" line-outs
Empeg on DC power in sled, using "front" line-outs (the empeg thinks its in the car)
The volume seems to be excactly the same.
Is this normal?
Lars
Lars
MkII 40gig 090000598
