#213210 - 14/04/2004 10:20 automatic function listing
RobotCaleb
ive recently been tasked with taking over a several year old project that is about a year from completion. it has been developed in Borland C++ Builder 3, and must stay that way. since this program is several hundred thousand lines long it is a pain to try to imagine what the previous coders may have named functions.
i am looking for a program that will parse the source code and create a function listing/flowchart-ish document. inputs and outputs would be nice, but not necessary.
does anything like this exist?
#213211 - 14/04/2004 10:28 Re: automatic function listing [Re: RobotCaleb]
JeffS
Loc: Atlanta, GA
There was a program by Power Builder called Sleuth QA that would profile the functions in Delphi and C++ Builder applications. I'm certain there would be a way to output these functions in a usable format, plus allow you to determine some valuable stats about each. Unfortunatly Power Builder has gone under, but I believe they open-sourced all of their code and made their products available, I’m just not sure where. A little searching around might find this out though.
-Jeff
#213212 - 14/04/2004 10:35 Re: automatic function listing [Re: RobotCaleb]
http://www.doxygen.org (that is, if it's mainly standard C++, I don't know whether Borland is full of crummy extensions).
#213213 - 14/04/2004 10:40 Re: automatic function listing [Re: RobotCaleb]
JeffS
Loc: Atlanta, GA
Alternatively, if you're feeling a bit clever you can create a map file (at least I believe you can do this in C++ builder 3). Select the option under the "linker" tab for your project options and it will generate a .map file when you compile and output it in the directory where your exe goes.
The map file isn't quite what you're looking for, as it gives the addresses of ALL functions the program accesses, including those in the VCL. However, I believe all user-defined functions should be grouped together, so you can use this data to create your flowchart. Just remember this is kind of an atomic bomb approach and you'll get WAY more information in this file than you actually need. The trick is whether or not you can isolate just the user created functions. I'd suggest doing a search on a known function name and then seeing how the other user functions are arranged in the file around it.
-Jeff
#213214 - 14/04/2004 10:40 Re: automatic function listing [Re: RobotCaleb]
mschrag
Loc: Richmond, VA
Probably not exactly what you want, but the Linux Cross-Reference Tool might be handy for such a situation too ... http://sourceforge.net/projects/lxr
#213215 - 14/04/2004 23:09 Re: automatic function listing [Re: peter]
I'll second doxygen!
#213216 - 15/04/2004 12:47 Re: automatic function listing [Re: peter]
RobotCaleb
i took doxygen (Doxygen? they use both) for a test drive. this program is pretty sweet.
it has done what i was hoping it would. thank you for pointing me there
#213217 - 15/04/2004 13:10 Re: automatic function listing [Re: RobotCaleb]
JeffS
Loc: Atlanta, GA
Glad you got a good solution!
FWIW, if you can get a hold of Sleuth QA (and you should since it's free now) I would. It's an invaluable tool for detecting memory leaks and locating bottle-necks.
-Jeff
