#219252 - 21/06/2004 20:34 emulate a USB device with a PC?
mschrag
Loc: Richmond, VA
Is it possible to connect one PC to another PC and have the first PC emulate a USB device for the second PC? Does this cause terrible explosions having two USB buses plugged into eachother? The situation here is that I want the PC to pretend to be an XBox controller so that I can write fancier automated test cases.
#219253 - 21/06/2004 22:23 Re: emulate a USB device with a PC? [Re: mschrag]
lectric
Loc: New Orleans, LA
To connect two computers together you will need a USB bridge. A USB Peer to Peer cable for file and hardware sharing or a USB Data Transfer Cable for file sharing. CAUTION: Using A to A USB cables, will short the two PCs' power supplies together, possibly destroying one or both machines or causing a fire hazard.
Dunno if it supports ANY usb/usb connection, but it definitely DOES do pc networking.
#219254 - 22/06/2004 02:26 Re: emulate a USB device with a PC? [Re: mschrag]
If you want the target PC to be able to emulate an arbitrary USB gadget, you'll need extra USB target hardware for the PC. I don't know whether that even exists. You'd be much better off using a car-player, possibly with a newer kernel to take advantage of all the new USB gadget stuff that's gone in recently.
