#229890 - 05/08/2004 03:56 I need a key swap program.
For my own reasons I need to make the number pad key "/" send an "_" . I searched version tracker but there seems to be a lot of chaff in there.
Any one have a recommendation for a simple utility to make that redefinition.
#229891 - 05/08/2004 04:22 Re: I need a key swap program. [Re: gbeer]
While I don't know of a specific tool, you might want to look for something that can edit locals, so you can just tell windows to change the locale to your custom one for the keyboard.
#229892 - 05/08/2004 05:38 Re: I need a key swap program. [Re: drakino]
lastdan
Loc: santa cruz,ca
I used 'keyboard express' to remap the '+' key on the number pad to be a tab.
I miss it so much I think I'll look for it again.
waddayaknow
http://www.keyboardexpress.com/
#229893 - 05/08/2004 05:45 Re: I need a key swap program. [Re: gbeer]
MarkH
Is it W2k / XP ? This might work for you
If not, you can tweak anything that returns a scan code via the registry which is painful, but you're only doing two keys so shouldn't take more than, ooh, an hour or so.
MS has info here
And there's a key scanner here
Regards
Mark
#229894 - 05/08/2004 13:20 Re: I need a key swap program. [Re: MarkH]
cushman
Loc: Erie, CO
I used the registry method to remap my right Ctrl key to Del on my Dell laptop. I couldn't stand not having a delete key next to the arrow pad. I have to say this is way better than having yet another program running to do the keymapping.
Mark Cushman
#229895 - 05/08/2004 15:29 Re: I need a key swap program. [Re: gbeer]
tms13
Loc: Lochcarron and Edinburgh
xmodmap
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#229896 - 05/08/2004 15:33 Re: I need a key swap program. [Re: tms13]
xmodmap
gnupg
#229897 - 06/08/2004 02:33 Re: I need a key swap program. [Re: tms13]
xmodmap
Careful your Penguin is showing.
KeyTweak seems to just allow moving scancodes around. Perfect is you are swapping the key caps around on the keyboard. "_" is a shifted key, so this isn't going to work. It's a great utilitty to keep from diving into the regestry.
I must be missing something about KeyboardExpress. a hotkey compiler that dosen't seem to allow selecting, for remap, character generating keys. Easy to use, but turning keypad / into underscore dosen't seem to be in its vocabulary.
Edited by gbeer (06/08/2004 03:23)
#229898 - 06/08/2004 05:27 Re: I need a key swap program. [Re: gbeer]
xmodmap
*pick* *pick* *pick* Oh, I didn't see you there... I was just picking nits!
xmodmap predates Linux by at least 4 years, if not more. The original was written by David Rosenthal, of Sun Microsystems, back in 1987 (or earlier).
#229899 - 07/08/2004 01:18 Re: I need a key swap program. [Re: canuckInOR]
xmodmap
But somehow saying "Your Standford University of Network is showing." didn't quite sound right.
