#233558 - 15/09/2004 22:56 java question
Loc: Los Angeles, CA
i'm trying to clean up some dirty data input before passing it on to another method.
the string in question is say, String s = "ST. JOHN%27%27S";
obviously, the %27%27 is actually supposed to be a '
but unfurtunately, s.replaceAll( "%27%27", "'");
no errors happen, but java doesn't seem to see that the pattern is in front of it's face. so, ultimately, i never get the desired effect. any suggestions?
#233559 - 15/09/2004 23:47 Re: java question [Re: image]
mcomb
Loc: San Carlos, CA
String.replaceAll() returns a modified copy of the String rather than doing an in place transformation so you need to do...
s = s.replaceAll( "%27%27", "'");
-Mike
#233560 - 16/09/2004 00:30 Re: java question [Re: mcomb]
yeah, i was doing that. it turned out to be a routine AFTER i had read the cityname in that was adding the extra chars. duh. thanks for the help.
#233561 - 16/09/2004 10:11 Re: java question [Re: image]
Cybjorg
Loc: Winston Salem, NC
Doh! I thought this thread was about coffee.
