Phew, you have no problem asking about 20 unrelated questions at the same time, have you?
You really have to try and stay on the track of what you are discussing, or people simply cannot help.
You can get Tony's LogoEdit from the RioCar site (see hot link at the top of the page). You will download a ZIP file to disk. Just create a new directory, unpack the ZIP file into it and run the program from there. There are instructions on Tony's site.
Which version of emplode is installed on your PC?
Which version of Windows are you using?
Which version of the player firmware (be precise) have you installed on your player (hopefully using the upgrader)?
Have you tried to install any third party software, such as HiJack? If so, can you provide us with details?
How many disks are in the player? Have they all been prepared by the disk builder firmware? Are they properly jumpered as Master and Slave drives?
Finally, you need to provide either logs of data exchanges with the player from emplode, or
at the very least a serial log of the boot of your player, or you may as well just sit there whistling Dixie! No-one here can see your screen or handle your player. You are our eyes and ears: if you are not accurate in what you report here and
PUT IN SOME EFFORT YOURSELF, then how do you expect people to help you?
