#247958 - 28/01/2005 17:49 Question about streaming audio...
Gallagher419
Is it possible to burn to cd a streaming audio file? I have three streaming audio files saved in Real Player but when I try to put the files into the cd burner of Real audio Real audio shuts down. I've tried right clicking on the file to "save as" but that option doesn't appear. Here is the file and it's info:
Title Conspiracy Theory
Category Music
Artist / Source SessionMIX
Year
File Name http://sessions.led-zeppelin.us/media_files/live/03-14-75-Conspiracy_Theory-a.ram
Send Media Link by E-mail
Length 54:22
File Size
Format RealAudio 8 with ATRAC3
Quality 132Kbps
Audio Channels 2
Rights Summary There are no rights or restrictions associated with this clip
Allow playback on PC No (play to authorize)
Content viewable until Unlimited
#247959 - 28/01/2005 17:57 Re: Question about streaming audio... [Re: Gallagher419]
CrackersMcCheese
You'd be better off saving the stream live as a wave file and burning that. Many apps are available for this. I use Creative Recorder that came free with my sound card.
Edited by Philip O'Hare (28/01/2005 17:59)
#247960 - 28/01/2005 18:04 Re: Question about streaming audio... [Re: CrackersMcCheese]
Gallagher419
Ok I understand but when I go to the website and click the streaming media link this what it says at the top of the page "ALL STREAMING MEDIA REQUIRES THE USE OF REAL AUDIO PLAYER" can I still save it as a wav file when playing it live using Real Player?
#247961 - 28/01/2005 18:06 Re: Question about streaming audio... [Re: Gallagher419]
CrackersMcCheese
Just play it as normal with real player - you can record at the same time.
#247962 - 28/01/2005 18:10 Re: Question about streaming audio... [Re: CrackersMcCheese]
Gallagher419
Ok thanks but one more thing how do I go about that? I've never tried it with streaming audio.
#247963 - 28/01/2005 18:23 Re: Question about streaming audio... [Re: Gallagher419]
CrackersMcCheese
Well while the file is playing I start up Creative Recorder and select the 'Record what You Hear' option and click record. It then records whatever your playing at the time. I'm not sure though if its availablev for free download. Maybe someone here can recommend other SW?
Edited by Philip O'Hare (28/01/2005 18:24)
#247964 - 28/01/2005 18:26 Re: Question about streaming audio... [Re: CrackersMcCheese]
Gallagher419
Just to make sure I understand you I can run it in Real Player and then record through the Creative Recorder? Thanks for your help I appreciate it.
#247965 - 28/01/2005 18:28 Re: Question about streaming audio... [Re: Gallagher419]
CrackersMcCheese
Yes - both at the same time. Best to start recording before you play the real player file so you don't chop off the start
Do you have the software or do you need an alternative?
#247966 - 28/01/2005 18:31 Re: Question about streaming audio... [Re: CrackersMcCheese]
CrackersMcCheese
Its probaly best to go for the 'wave' option rather than 'what you hear'. That way you can still use the pc and the mouse clicks won't be recorded too!
#247967 - 28/01/2005 18:32 Re: Question about streaming audio... [Re: CrackersMcCheese]
Gallagher419
I found something through download.com called sound capture I'm going to try it now but if have any other alternatives let me know. Thanks!
#247968 - 28/01/2005 18:34 Re: Question about streaming audio... [Re: Gallagher419]
CrackersMcCheese
Let us know how you get on. I'm not aware of other software but someone else may chip in there
#247969 - 28/01/2005 18:38 Re: Question about streaming audio... [Re: CrackersMcCheese]
Gallagher419
I'll keep you up to date as of now I'm recording will let you know how I make out. Thanks Philip! On an off note my wifes maiden name is O'Hare.
#247970 - 01/02/2005 02:10 Re: Question about streaming audio... [Re: Gallagher419]
newguy1
Loc: Massachusetts,USA
I was able to create a wav file from that link in about 10 minutes using a program called X-fileget and this technique .Let me know if you need more info.
MIKE 80Gb RIO
#247971 - 01/02/2005 06:12 Re: Question about streaming audio... [Re: Gallagher419]
bonzi
When I want to save a media stream (e.g. lectures from MIT) I use NetTransport (also serves as very good general-purpose download manager; the most recent version is shareware, but one can still find 1.87, which was free). If I then want to archive them, I simply use any old CD-ROM burning SW (like Nero or anything), or even built-in XP functionality.
Of course, I then need the app they were originally intended for in order to listen/watch them, so perhaps this is not an answer to your question
Edited by bonzi (01/02/2005 06:13)
#247972 - 02/02/2005 02:08 Re: Question about streaming audio... [Re: bonzi]
newguy1
Net transport seems much better than the program I was using.It was able to download the stream that the other program couldn't
It should work for Gallagher no problem.
MIKE 80Gb RIO
