#252359 - 23/03/2005 02:41
e2fsck message at bootup, what does it mean?
Loc: Southern California
I get this message during bootup and was wondering how to get rid of it: "EXT2-fs warning: checktime reached, running e2fsck is recommended" I've followed the instructions HERE for "unchecked fs" & " mount count reached" and the fsck did correct some errors, but my player still can't rebuild it's own database properly. Does my error message mean something else maybe?
Bodybag - So Cal Not a Whiner any more!!!
#252360 - 23/03/2005 02:50
Re: e2fsck message at bootup, what does it mean?
[Re: bodybag]
Quote: but my player still can't rebuild it's own database properly.
Did you try this?
#252361 - 23/03/2005 03:04
No I haven't, but I did use WsFTP to "delete" the database, playlists and tags and then let the player rebuild them on it's own, followed by a sync in Emplode. Wouldn't that be the same thing?
I'm running fsck again and here's what has happened so far:
empeg:/empeg/bin# ro empeg:/empeg/bin# umount /dev/hda4 empeg:/empeg/bin# umount /dev/hdc4 empeg:/empeg/bin# swapon /swapfile Adding Swap: 16028k swap-space (priority -1) empeg:/empeg/bin# fsck -fay Parallelizing fsck version 1.19 (13-Jul-2000) empeg:/empeg/bin# fsck -fay /dev/hda4 Parallelizing fsck version 1.19 (13-Jul-2000) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/ hda4 is mounted. Pass 1: Checking inodes, blocks, and sizes fsck -fay /dev/hdc4 swapoff /swapfile sync Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information Block bitmap differences: -32586791 -32590110 -32590111 -32590112 -32590113 -32 590114 -32590115 -32590116 -32590117 -32590118 -32590119 -32590120 -32590121 -32 590122 -32590123 -32590124 -32590125 -32590126 -32590127 -32590128 -34926723 -34 926724 -34926725 -34926726 -34926727 -34926728 -34926729 -34926730 -34926731 -34 926732 -34926733 -34926734 -34926735 -34926736 -34926737 -34926738 -34926739 -34 926740 -34926741 -34926742 -34926743 -34926744 -34926745 -34926746 -34926747 -34 926748 -34926749 -34926750 -34926751 -34926752 -34926753 -34926754 -34926755 -34 926756 -34926757 -34926758 -34926759 -34926760 -34926761 -34926762 -34926763 -34 926764 -34926765 -34926766 -34926767 -34926768 -34926769 -34926770 -34926771 -34 926772 -34926773 -34926774 -34926775 -34926776 -34926777 -34926778 -34926779 -34 926780 -34926781 -34926782 -34926783 -34926784 -34926785 -34926786 -34926787 -34 926788 -34926789 -34926790 -34926791 -34926792 -34926793 -34926794 -34926795 -34 926796 -34926797 -34926798 -34926799 -34926800 -34926801 -34926802 -34926803 Fix? yes
Free blocks count wrong for group #3977 (0, counted=1). Fix? yes
Free blocks count wrong for group #3978 (0, counted=19). Fix? yes
Free blocks count wrong for group #4263 (3783, counted=3864). Fix? yes
Free blocks count wrong (42904651, counted=42904752). Fix? yes
Inode bitmap differences: -16578 Fix? yes
Free inodes count wrong for group #259 (59, counted=60). Fix? yes
Free inodes count wrong (593288, counted=593289). Fix? yes
/dev/hda4: ***** FILE SYSTEM WAS MODIFIED ***** /dev/hda4: 16439/609728 files (24.9% non-contiguous), 35139018/78043770 blocks
#252362 - 23/03/2005 03:08
[Re: bodybag]
Quote: No I haven't, but I did use WsFTP to "delete" the database, playlists and tags and then let the player rebuild them on it's own, followed by a sync in Emplode. Wouldn't that be the same thing?
Not sure.
Your shell log there indicates some disk trouble. Not sure if that means hardware problems or what. Perhaps someone more experienced can fill you in on what it means.
#252363 - 23/03/2005 04:24
[Re: bodybag]
fsck of the second drive looked like this:
empeg:/empeg/bin# fsck -fay /dev/hdc4 Parallelizing fsck version 1.19 (13-Jul-2000) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/ hdc4 is mounted. Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information /dev/hdc4: 30997/609728 files (25.0% non-contiguous), 77809944/78043770 blocks empeg:/empeg/bin# swapoff /swapfile empeg:/empeg/bin# sync empeg:/empeg/bin#
#252364 - 23/03/2005 04:29
[Re: bodybag]
But in the next reboot, I still got the same error message:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v417 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Sat Jan 15 19:12:21 EST 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 40103915) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 206f6972 'rio ' Found custom animation at offset 0x98378 Tuner: loopback=0, ID=-1 empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004e80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IC25N080ATMR04-0, ATA DISK drive hdb: IC25N080ATMR04-0, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63 hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:4 b Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Remounting first music partition read-only Remounting second music partition read-only Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: Atlantic/South_Georgia Hijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection" hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000
#252365 - 23/03/2005 04:33
[Re: bodybag]
Wait, what part are you telling me is an error message? The checktime thing is not an error message, I don't think. My concern is the fact that you can't rebuild your database. That's a more serious issue.
#252366 - 23/03/2005 08:50
[Re: bodybag]
Quote: Wouldn't that be the same thing?
Not if it didn't work, no ![](/ubbthreads/images/graemlins/wink.gif)
Your final bootlog looks fine. The checktime warning is for the root filesystem. If you do a lot of fiddling with your root filesystem -- mounted read/write -- then fsck it next time, otherwise you can completely ignore it.
#252367 - 23/03/2005 19:27
[Re: peter]
Ok, I fsck'd AND did a manual rebuild of the database. playlists & tags as described here. My player still didn't build the database & playlists correctly? The playlist structure is in total chaos! I don't get it... why can't this player rebuild it's own playlist's right? Help please
Oh yeah... I also re-flashed the kernal with 2.0 developer and re-flashed with Hijack, still doesn't work right.
Edited by bodybag (23/03/2005 19:41)
#252368 - 23/03/2005 19:43
[Re: bodybag]
Quote: My player still didn't build the database & playlists correctly? The playlist structure is in total chaos! I don't get it... why can't this player rebuild it's own playlist's right? Help please
You mean, the database rebuild completed and the player started, but the contents of the playlists aren't what you expected?
Once you've had messages like this from fsck:
Quote: Free blocks count wrong for group #3977 (0, counted=1). Fix? yes
then all bets are off. Your filesystem was corrupted and has been repaired as well as possible. Some files are probably corrupt. Sounds like some of them are playlist files. If you look at the player in Emplode/Jemplode/whatever then the playlists will be broken in the same way that they are on the player. Rebuilding the player's database only serves to reread the corrupted files: nothing on the player can recreate the pre-corruption versions.
As for what caused the filesystem corruption in the first place, the usual culprits are (a) crash or reboot with the filesystem mounted read/write, or (b) impending disk failure. But impending disk failure usually has other symptoms too.
#252369 - 23/03/2005 19:50
[Re: peter]
Yeah, I understand this, but my player is an EXACT COPY of one of my other players, and that player works fine!!!
I removed everything from the problem player by doing a disk builder on it (both drive0 & drive1), then FTP'd the entire contents of drive0/fids & drive1/fids from my "Good" player onto it. Shouldn't that make them identical?
#252370 - 23/03/2005 19:58
[Re: bodybag]
Quote: I removed everything from the problem player by doing a disk builder on it (both drive0 & drive1), then FTP'd the entire contents of drive0/fids & drive1/fids from my "Good" player onto it. Shouldn't that make them identical?
Yes, it should! If you have a good copy of the entire contents, try figuring out the FID of an example broken playlist (e.g. 230), and go and find the corresponding file (called "230") on both the good and bad players. FTP the playlist files to your PC (from both players) and compare them. (They're binary, so you'll need something like hexdump or "od -t x4".) What sort of brokenness are we talking about here? Extra FIDs in playlists? FIDs missing? Nonsense fids (e.g. not multiple of 16)? Are both players the same software version?
#252371 - 23/03/2005 20:18
[Re: peter]
FWIW, here's a copy of an fsck I did on the Good player a day or so ago when I started messing with the problem player:
Starting bash.
hda5 is mounted.
/dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks
hda4 is mounted.
fsck -fay /dev/hdc4
swapoff /swapfile
sync
/dev/hda4: 16233/609728 files (24.2% non-contiguous), 34552704/78043770 blocks
hdc4 is mounted.
/dev/hdc4: 30993/609728 files (25.8% non-contiguous), 77809903/78043770 blocks
empeg:/empeg/bin# exit
logout
Shell exit
As you can see, it found no problems like I had with my other player.
Quote: What sort of brokenness are we talking about here? Extra FIDs in playlists? FIDs missing? Nonsense fids (e.g. not multiple of 16)? Are both players the same software version?
I'm talking about FIDs with 0 (zero) refs, which I should have none of. I'm talking about when I find those FIDs and copy them to paste them into the playlist they belong to, I find additional FIDs in those playlists that don't belong there in the first place.
For example: I open my player in Emplode and it opens with a warning that the lenght of playlist XXX does not match what it should have been, at this point I know I have a problem. I click the "All Tracks" selection and see that all the songs belonging to the CD Social Distortion - Somewhere Between Heaven & Hell have zero refs. I copy these songs from the All Tracks window and proceed to paste them where they SHOULD HAVE BEEN. The playlist folder for that CD still exists so I open it to paste the songs and find that there are random songs from Bad Religion are in there. I paste the Social D stuff and copy the Bad Religion stuff to go put it where it goes and find things in the Bad Religion folder that aren't supposed to be there. This basically goes on and on until I too frustrated by the mess to continue the reconstruction.
Additionally, both players are 2.0 final with hijack v417
#252372 - 23/03/2005 20:37
[Re: bodybag]
Hang on, did you do this before or after the fsck which reported the errors?
It was immediately before that fsck that your filesystem got corrupted. If you haven't blanked and re-copied the bad player since then, it's not surprising that it's still different from the good player.
#252373 - 23/03/2005 20:45
[Re: peter]
No Peter, I've been having trouble with this player for a while now. I've done this copy & replace thing many times... before & after doing an fsck. The recent fsck was just another effort to see if I could "fix" the issue.
#252374 - 23/03/2005 20:51
[Re: bodybag]
Quote: No Peter, I've been having trouble with this player for a while now. I've done this copy & replace thing many times... before & after doing an fsck. The recent fsck was just another effort to see if I could "fix" the issue.
So have you or haven't you re-blanked and re-copied since the last failing fsck?
Perhaps it's during your copying process that you're at some point rebooting with the drives still mounted read/write? Could you describe your copying steps in excruciating detail?
Edit: Just to amplify what I said before, once fsck has fixed an error then everything on the drive is suspect and you should expect corruptions of the sort you experienced until you delete and re-copy all content. The ONLY issue here is what caused the error that fsck found.
#252375 - 23/03/2005 21:04
[Re: peter]
Since the fsck I posted I have not re-blanked and re-copied.
My copying process is fairly simple:
I put Hijack on the player and then contact the player via WsFTP. I mount the drives RW by sending a site command. Then I open the drive0 fid's directory on the PC and the Empeg and select all the FIDs on the PC. I double check to make sure it's set to transfer the files in binary and then hit transfer. When it finishes, I do the same for drive1 (Normally this process takes about 3 days, it's a little over 110gb). Then I delete the drive0/var/database, playlists & tags. Mount the player RO and exit WsFTP. Reboot the player and let it do it's thing then sync in Emplode. Done
At this point, the problem player messes up the playlists, so I connect with WsFTP again, mount RW, delete drive0/var/palylists, database & tags and send over a copy of drive0/var/palylists, database & tags from my good player, then mount RO again and everything is happy!!!
#252376 - 23/03/2005 21:31
[Re: bodybag]
Quote: Since the fsck I posted I have not re-blanked and re-copied.
OK, in that case there's no mystery about why all your playlists are corrupt.
Quote: I put Hijack on the player and then contact the player via WsFTP. I mount the drives RW by sending a site command. Then I open the drive0 fid's directory on the PC and the Empeg and select all the FIDs on the PC. I double check to make sure it's set to transfer the files in binary and then hit transfer. When it finishes, I do the same for drive1 (Normally this process takes about 3 days, it's a little over 110gb). Then I delete the drive0/var/database, playlists & tags. Mount the player RO and exit WsFTP. Reboot the player and let it do it's thing then sync in Emplode. Done.
That all sounds perfectly sensible. Next time it might be worth watching the serial port while doing this (in Teraterm or Hyperterminal or whatever), in case there's a crash or something. You could also ensure that remounting the player read-only worked, by using your FTP client to fetch the file "/proc/mounts" (it has a line for each partition, including "ro" for read-only ones and "rw" for read/write ones).
Or, once you've exited WsFTP, you could quit the player using the serial connection (type Ctrl-C), and issue the "rom" command directly. Again, you can do "cat /proc/mounts" to see if anything has been left read/write.
Basically, the filesystem must have got corrupted while it was mounted read/write. If the only times it's been mounted read/write since being blanked are (a) during your FTP copy, and (b) during the Emplode sync (an Emplode sync always involves a period of read/write mounting), then it must be during one of those two times that something bad (e.g. a reboot) happened.
#252377 - 25/03/2005 01:43
[Re: bodybag]
Quote: but my player is an EXACT COPY of one of my other players, and that player works fine!!!
Um, not any more it's not. Not after those FSCKs. ![](/ubbthreads/images/graemlins/smile.gif)
#252378 - 26/03/2005 04:23
Loc: San Carlos, CA
Probably not before either. Otherwise the fscks wouldn't have been necessary!
