#262219 - 05/08/2005 01:23 jEmplode 70
mschrag
Loc: Richmond, VA
http://www.jempeg.org
About a 5 line change in this version
I'm HOPING this fixes all the funky unreferenced playlist-related problems. If you already had unref'd playlists, obviously it will do the same as it used to, but hopefully new imports shouldn't be as goofy. Let me know.
#262220 - 07/08/2005 23:37 Re: jEmplode 70 [Re: mschrag]
TigerJimmy
I'm sort of late to this issue. I don't know if my experience is related to unreferenced playlists or not.
Using the 69.000...1 version, it moved several playlists around on me. Specifically, it moved playlists which were sub-playlists to the root level. I am not using soups.
Let me know if I can help in any way.
FWIW,
Jim
Oh, PS: what kind of dog is that. He's really cool looking!
Edited by TigerJimmy (07/08/2005 23:39)
#262221 - 08/08/2005 00:17 Re: jEmplode 70 [Re: TigerJimmy]
Happy Birthday wfaulk
Yes, that's the same issue.
#262222 - 08/08/2005 13:31 Re: jEmplode 70 [Re: mschrag]
Here's another thing you might want to look at.
When I create a new playlist and put tracks in it, it always seems to fill out the playlist's various metadata with "Various", despite it being a single album. Not really a big deal, but annoying.
When I get a jEmplode and empeg in front of me next, I'll let you know more.
#262223 - 08/08/2005 15:22 Re: jEmplode 70 [Re: wfaulk]
Oh, and here's a tip: When you do a refs=0 search and you see a playlist named "Playlists" or "empeg-car" or maybe whatever the name of your player is, don't delete that. That's the root playlist. Deleting it can screw a bunch of stuff up, apparently. Maybe that shouldn't show up in a refs=0 search?
#262224 - 08/08/2005 15:24 Re: jEmplode 70 [Re: mschrag]
chuckcheeze
is the new jemplode v70 up?
when i download it, i did notice a new splash screen, but it the title bar is v69?
just asking. thanks
#262225 - 08/08/2005 15:28 Re: jEmplode 70 [Re: wfaulk]
Okay, so here's how to reproduce the "various" bug I'm talking about. Go to an existing playlist. (In my case, the already existing artist playlist off of the root playlist.) Click the "New Tune Directory" button. Select the directory to be imported. (In my case, the directory that holds the mp3s for the new album I just ripped.) A new playlist is created. It has "Various" set in its metadata for Artist, Genre, Source, and Year, despite the fact that all of those pieces of data for the included tracks are the same. If I bring up the properties dialog, those fields are colored in yellow (instead of the normal blue-grey), but no text appears there; it shows "Various" in the advanced tab.
#262226 - 08/08/2005 16:23 Re: jEmplode 70 [Re: chuckcheeze]
mschrag
Loc: Richmond, VA
Ah yeah I forgot to change the version # ... I hate that version number. I always forget to change it.
#262227 - 08/08/2005 16:25 Re: jEmplode 70 [Re: wfaulk]
mschrag
Loc: Richmond, VA
Re: refs=0 -- That's actually kind of a tricky fix, because those predicates evaluate on their own, so there's not an easy way to make playlists not appear w/o a bunch of weird hacks. HOWEVER, Playlists should probably not be deletable.
#262228 - 08/08/2005 17:57 Re: jEmplode 70 [Re: mschrag]
Hahaha - I thought it was deliberate.
ahem
#262229 - 09/08/2005 22:27 Re: jEmplode 70 [Re: frog51]
JeffreyB
Loc: Cincinnati, OH
Did 70 fix the "Build From Memory" bug???
JeffreyB
#262230 - 09/08/2005 23:53 Re: jEmplode 70 [Re: JeffreyB]
mschrag
Loc: Richmond, VA
Nope
#262231 - 19/08/2005 18:27 Re: jEmplode 70 [Re: frog51]
Thorgal
Loc: Switzerland
Hi Sorry for this question, but on my PC with Swiss French regional settings, the shortcut to move up-down a item in the playlist, show me Ctrl+Haut and Ctrl+Bas. Which mean Ctrl+Up and Down in english...
BUT, it dows not work... I have to click manually the MenuItem to move an item.
Is it normal ? Or what is supposed to be the "correct " shortcut ?
Txs.
David
#262232 - 20/08/2005 21:21 Re: jEmplode 70 [Re: Thorgal]
Defiler
I get a 404 on the "latest source" download link.
WIll that be back someday?
#305078 - 12/12/2007 07:28 Re: jEmplode 70 [Re: mschrag]
anyone got any idea what these changes were?
