#262270 - 05/08/2005 14:19
emplode sync problems after disk upgrade
Loc: Bjørkelangen, Norway
Greatings
I have had simular problems with emplode prior to the disk upgrade, but never this persistant. Emplode stops transferring files and the program halts when syncronizing with the player.
This is what I have done to the player so far:
Took out the two IBM disks (20GB each)
Installed the two new WD600 disks (60GB each)
Installed the builder image
Installed the developer image on both disks
Everyting went well - no errors at all, thanks to the great FAQ.
Hooked the player up to my home network.
Fired up emplode and started moving files.
I did not do any copying from the old disk. ICE I can just mount the old disks and all will be back to normal (wich I'm close to be doing).
Emplode crashed after six, seven minutes. The error message is: 'the length of playlist..' etc. on all the files I try to transfer.
I did a physical check on the cables, the solderings, the cables again, and all seems to bee in working order.
I installed the builder image and the developer image one more time, with the same results - emplode halts.
I then installed the Hijack - the hope was that this would solve the problems. It did not.
Any thing I can do here?
win XP Pro SP2
XP firewall
2.0 kernel
2.0 emplode
Hijack v439
Start up log:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v439 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Jul 28 13:21:31 EDT 2005
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 7, serial number 90000824) 12MB DRAM
Command line: mem=12m
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
Tuner: loopback=0, ID=-1 hdb3 hdb4
empeg display initialised.K: ext2 filesystem found a
empeg dsp audio initialised
RAMD
empeg dsp mixer initialisedisk] into ram disk... done.
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a0tem).
empeg
Press Ctrl-A to enter pump...nge_root: old
o
empeg state support initialised 0089/88c1 (save to d0005b80).vice ide0(3,4)): ext2_chec
empeg RDS driver initialised
k_descripto
empeg power-pic driver initialised in group (block 0)!
RAM disk driver initialized: 16 RAM disks of 4096K size-fs: group descriptors corrupted !
empeg single channel IDErong fs type, bad option
Probing primary interface...
hdb: WDC WD600UE-00HCT0, 57231MB w/2048kB Cache, CHS=7296/255/63uch file or directory while determining whether /dev/
smc chip id/revision 0x3349
Linux ext2 fi
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)abel=
457088 inodes, 58500697 blocks
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:3
First data block=1
Block s
8e
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Trying to unmount old root ... okay
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4054d000
Kyrre 'enni mizpellings ar dju tu kompjutr error' www.kyrre.noNorway, Hijack'ed 120GB upgrade, MKII, tuner, green, red, blue, yellow, illuminated. Looking good!
#262271 - 05/08/2005 14:37
Re: emplode sync problems after disk upgrade
[Re: kjohanss]
There have been reports of problems with emplode when trying to move too many playlists to the player at once. (Remember that a windows folder counts as a playlist when putting fresh stuff on the player.) Try doing your uploads to the player in small batches. See if that works, then report back.
#262272 - 05/08/2005 15:41
Quote: There have been reports of problems with emplode when trying to move too many playlists to the player at once. (Remember that a windows folder counts as a playlist when putting fresh stuff on the player.) Try doing your uploads to the player in small batches. See if that works, then report back.
Thank you - I have done som research. Now working
I now move one folder at a time. I didn't move that many folders earlier, but this seems to work better. I also make sure there are no filetypes other than mp3 in the folders I move. Emplode tells me if there are files not compatible, but it seems that also was a problem - no errors so far.
Beeing a novice on this subject (still after being an empeg owner since fall 2000), it was fearly easy to change disks. Now I can fill it up will ALL my music!
#262273 - 10/08/2005 09:59
Still having problems syncronizing. If I move one or two albums at a time, it's usually ok. Moving three or more is a risky business. And emplode does not try to reload the files. I have to work my way through all the files and start syncing over again from where emplode stopped working.
Is it possible to have the empeg appeare as a drive letter in windows so I can just move the files that way?
I tried the FTP function, but that's not for moving music files, is it?
#262274 - 10/08/2005 10:25
[Re: kjohanss]
Okay. Something really weird is going on. You are doing your sync via ethernet today. Are you going through any kind of switch / hub? Can you try directly connecting the player to the computer via a crossover cable? Also, the player only supports 10Mbps - some switches / hubs / cards left to autonegotiate have a really hard time doing so.
#262275 - 10/08/2005 13:24
[Re: kjohanss]
Quote: Is it possible to have the empeg appeare as a drive letter in windows so I can just move the files that way?
No.
Quote: I tried the FTP function, but that's not for moving music files, is it?
Correct.
The problems you're experiencing indicate something else is going wrong. Perhaps something wrong with the hard disk, or with the network connection. See if you can upload with USB (after reading this).
Also, are you absolutely sure you used the builder image properly? For instance, if there was already data on the disk, it would say "disk appears to be already built" and require you to press Enter on the serial port before it formats the disk. And if there are two disks, did you run builder twice, once with each disk in the primary slot?
