#264627 - 06/09/2005 13:20 Shallow cabling
I got a new AV receiver recently and I have a problem. It's deeper than my old one and the plugs on the cables I have are too long so that they'd have to poke through the panelling in the back of my entertainment center in order for it to fit. So what should I do?
The first option I see is to buy new cables that have shorter inflexible parts, but that probably means lower-quality cables. I mean, I'm on board with the notion that the big fat cables you see these days are overpriced, but I also think that the little cheap-ass cables are probably lousy. Or am I wrong? Or does someone know of decent cables that have shorter plugs? And then there's the two S-Video cables I need. I don't know of any of them that have much shorter plugs.
Another option is to buy right-angle cables or adapters. But I can't seem to find any for sale locally. And I don't know that anyone makes right-angle S-Video cables or adapters.
Any other ideas? I really need to get them tonight. The wife's already mad that the living room is in a state of disarray.
#264628 - 06/09/2005 13:32 Re: Shallow cabling [Re: wfaulk]
cushman
Loc: Erie, CO
Trim the back paneling of the entertainment center to make it fit? Unless you have a custom-built entertainment center the back panel might just be cheap paneling and this would also increase airflow.
Mark Cushman
#264629 - 06/09/2005 13:41 Re: Shallow cabling [Re: wfaulk]
robricc
Here are right-angle s-video cables. Probably not something available locally though. You should be able to find right-angle RCA cables at a car stereo shop.
#264630 - 06/09/2005 13:47 Re: Shallow cabling [Re: cushman]
I did mention my wife was already freaking out, right?
#264631 - 06/09/2005 23:29 Re: Shallow cabling [Re: cushman]
I'll second the motion. Get out the Sawsall.
On the wife front, tell her there are three options, buy a different piece of electronics, buy a different entertainment center, but that the least expensive is to cut a hole in the back, and if the result is bad, then buy a new entertainment center. Remember to get a piece of black gabardine to hang behind the hole. Maybe two pieces, one to tack to the inside.
#264632 - 07/09/2005 01:44 Re: Shallow cabling [Re: wfaulk]
jimhogan
Loc: Seattle, WA, U.S.A.
Perhaps not timely enough, but a search on partsexpress.com for "right angle" reveals right-angle RCA adapters among others. Even TOSLink.
The beauty of bachelorhood is being able to use the Sawzall as one sees fit.
Jim
#264633 - 07/09/2005 12:05 Re: Shallow cabling [Re: jimhogan]
Yeah. They have right-angle RCA adapters at the RadioShack. $4 a piece, though.
