So I came back from classes, started up my car and the empeg booted fine and then right on the screen where its supposed to resume the song, it's just frozen. None of the buttons work nor the knob, except when you hold down the knob and the Hijack menu appears. So I rebooted it. It still boots up fine and comes back to the same exact point in the song that was last playing but nothign plays and the song isn't moving forward. It appears the player is hard frozen but like I said you are able to access the Hijack menu.
I brought it inside and grabbed a dump:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v439 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Jul 28 13:21:31 EDT 2005
Processor: Intel StrongA
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30103111) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005b80).
empeg RDS driver initialised
RAM disk driver initialized: 16 RAM disks o
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:0
7
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Tried to mount /dev/hda4 as reiserfs but got error 19 <---- i assume this is the culprit and guessing it means a bad drive
Starting player
Timezone: Atlantic/South_Georgia
/bin/sh: /usr/local/bin/telnetd: hijack: removed menu entry: "Hard Disk Detectio
n"
No such file hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
/bin/sh:kftpd: listening on port 21
exec: /usr/local/bin/telnetd: cannot execute: No such file or directory
Using non-standard cache size 68 (bonus 0Mb, adjustment 32)
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4053a000
If it is a bad drive, obviously I'll have to replace it. Is there an easy way to salvage the music thats on the other drive?
