The standard PC X800 definitely doesn't support Dual Link DVI (the resolution/refresh combination you posted is the maximum analog resolution). The Mac X800 does however, as does the Mac/PC (Hybrid) 9600 Pro. Upward from there (but still in the consumer space) you'd be looking at newer products in the X1xxx series for that feature. Also keep in mind you're looking specifically for Dual Link DVI support. That only needs one port, whether or not the card supports Dual DVI (which is two ports for two monitors and not the same thing).
