Ok, I put in a single new 40GB hard drive. Did the Builder & then put on the developer image.
I didn't put HiJack on yet, I'm just trying to make sure it's working. Here's what I got from the serial port:
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 40104030)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: CSD CAV040H, ATA DISK drive
hda: CSD CAV040H, 38154MB w/8192kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:b
e
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Starting player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
It won't put songs on the disk even though it can go through the sync. So is this disk mounted as read only?
