#275825 - 09/02/2006 10:17 Player Locks Up
JeffreyB
Loc: Cincinnati, OH
Hello All...
I was running version 3.00 alpha 10, HiJack 400. Tried to use jEmplode to send songs to the player, but it kept stopping halfway through and just sitting there. I decided to upgrade to the latest HiJack using jEmplode and it hung too, just like when sending songs to the player. This caused my firmweare to be corrupt so I reflashed with v3.00 alpha 11. Now the player boots but hangs and locks up after loading the database/playlists. No response from buttons. Screen animations halt. I did an fsck and did a manual delete/rebuild of database. Still same problem. I've got some errors shown with the serial_notify with what looks like one song. Log below...
Thanks,
Jeff
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #15 Mon Jul 25 18:52:48 BST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 30102985)
Command line: mem=16m
POSIX conformance testing
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
ttyS00 at 0xf8010000 (irq = 15) is a
Signature is 20706d65 'emp '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004780).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:a
9
Partition check:
empeg-pump v0.03 (19980601)
change_root: old root has d_co
Mounting proc
Starting player
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4075c000
serial_notify_thread.cpp: 116:@@ N6
serial_notify_thread.cpp: 117:@@ F0x4e0
serial_notify_thread.cpp: 118:@@ TYou Keep Runnin' Away
serial_notify_thread.cpp: 119:@@ A38 Special
serial_notify_thread.cpp: 120:@@ GRock/Pop
serial_notify_thread.cpp: 170:@@ S1
serial_notify_thread.cpp: 180:@@ #4e0 0:03:21
Edited by JeffreyB (09/02/2006 10:18)
#275826 - 09/02/2006 12:43 Re: Player Locks Up [Re: JeffreyB]
Bad Track?
I occasionally get "bad track"-like behavior with the Alphas on a perfectly good track. I can usually skip to the next track if I press the next button repeatedly while it finishes booting. After that, a reboot and I'm back up and running.
#275827 - 09/02/2006 18:15 Re: Player Locks Up [Re: JBjorgen]
schofiel
To be honest, you'd be better off on A11 anyway. Not sure what the issue is here: do you have any third party apps on requiring cache setting mods?
#275828 - 09/02/2006 18:33 Re: Player Locks Up [Re: schofiel]
JeffreyB
Loc: Cincinnati, OH
OK, I flashed back to release 2.00 and rebuilt the database. All went well. I then reflashed to v3.00a11 and it seems to be working now...
So is the world of alphas...
Thanks guys,
Jeff
