#279712 - 18/04/2006 07:24 Simple video editor software needed
Hi all,
I'm currently busy converting some old VHS tapes to DivX. To be able to do this, I bought a Plextor ConvertX PVR device. (great device BTW, recommended!)
I do this in two steps: I first digitize the tape into an .mpg file, and then I run that file with the DivX creation software. This works very will with the software that was provided with the Plextor unit.
However, going about it this way does mean that I have to stay with my VCR to be able to stop it at the appropriate moment, since there is no software shipped with the Plextor to actually split that .mpg file into smaller files. (I need this since there's usually more that one movie/series on one tape)
So now I'm looking for some free video editor software which can do the following:
* load up an .mpg file (of an entire 4 hr tape)
* split up the .mpg file into 2 or more separate files (depending on how many movies/series were recorded into those 4 hrs)
* delete split sections which I don't need (commercials etc.)
* save all these new sections into new separate .mpg files.
I can then put all these files into my DivX creator batch list, and let them being created over night.
I don't think that what I'm asking for is very difficult, and suspect that even the simplest programs will be able to do this. However, I'm completely new when it comes to this, and I have no idea where to look.
Could somebody point me towards a nice, clean and simple programa which can do this please?
Thanks!
#279713 - 18/04/2006 07:27 Re: Simple video editor software needed [Re: BartDG]
boxer
Loc: Yorkshire UK
I swear by VideoReDo, having tried a few, it's that easy to be precise, but it's not free: $49.99.
#279714 - 18/04/2006 07:42 Re: Simple video editor software needed [Re: boxer]
VideoReDo indeed looks very good, and exactly what I'm looking for. Hmmm... maybe I should consider it... The price is not really that high either.
I'll see what other users have to say before I make a final decision, but this one is certainly high on my list!
Thanks!
#279715 - 18/04/2006 07:57 Re: Simple video editor software needed [Re: BartDG]
I also use VideoReDo for some of my projects as well. Well worth it for editing sections of video like that.
#279716 - 18/04/2006 10:14 Re: Simple video editor software needed [Re: pgrzelak]
I've tried the trial version of this software and it's indeed very good. It does exactly what I want it to.
The trial last for 15 days. Most likely I won't get this project over and done with within this timeframe, but if I don't make it, I'll buy the package. Seems to me it really is worth it.
Thanks again!
#279717 - 18/04/2006 15:52 Re: Simple video editor software needed [Re: BartDG]
davekirk
Loc: Las Vegas
It isn't as pretty, but VirtualDub is totally free.
#279718 - 19/04/2006 01:02 Re: Simple video editor software needed [Re: BartDG]
I've been trying out EditStudio. Unfortunately I haven't been able to use it much. Sorry I can't tell you more, I'm just throwing it out there as another alternative to Premiere. There's Premiere Elements, but then you're still left with an Adobe product (I don't like Adobe).
I'm going to have to try that VideoReDo. I only tried EditStudio because it's recommended by the makers of DVD-lab.
*edit*
Okay, you know what? Screw my suggestion. This VideoReDo is fantastic. I just tested it on a Tivo extracted MPG and it worked like a charm. I like that program a lot better than cutting the video out in TyTools.
Edited by Dignan (19/04/2006 01:12)
#279719 - 19/04/2006 01:38 Re: Simple video editor software needed [Re: Dignan]
oliver
Awhile ago I had to record the commercials from the Superbowl for my dad, I used MPEG2VCR, it was quite easy to use and I was able to hook up the PowerMate Knob, after a few minutes I had enough shortcuts setup where I could use only the knob to trim the football junk out of the huge mpg.
MPEG2VCR also isn't free, I think it's about $45 for a license.
Edited by oliver (19/04/2006 01:40)
#279720 - 19/04/2006 08:11 Re: Simple video editor software needed [Re: oliver]
...I had to record the commercials from the Superbowl for my dad ... to trim the football junk out...
For some reason, I find this very funny.
By the way, I think I may have posted about ad-rag.com a while back for their archives. Really quite handy.
#279721 - 19/04/2006 12:17 Re: Simple video editor software needed [Re: oliver]
I really like the idea of the PowerMate, and I'd love to try that with VideoReDo. I'll have to also give MPEG2VCR a try. They appear to basically be the same program.
How does the PowerMate work for video editing? I mean, how do you set it up to control that?
#279722 - 19/04/2006 21:20 Re: Simple video editor software needed [Re: Dignan]
oliver
You can setup per-application hot keys in the taskbar driver, for rotate left/right, click, click and rotate, and I think double click. If I can remember correctly, you can also set how many key-presses are applied for each signal received from the knob. It worked out really nicely.
I'd rotate then click to set a start point, double click to set the end point. I think then I'd use the regular keyboard shortcut to cut/delete the selection. The click+rotate was a little hard for making a long selection, so I set that to around 30 frames advancements.
Edited by oliver (19/04/2006 21:21)
#279723 - 20/04/2006 12:17 Re: Simple video editor software needed [Re: oliver]
Thanks, I'll be testing that out when my PowerMate arrives tomorrow It got it for $39 on Amazon. I remember seeing it a while ago and thinking it would be pretty cool to have one, but I didn't really have any use for it. Now that it's so much easier to do this MPG editing, this is something I really need.
Two questions:
1) what speed/number of frames do you have the device set up for when rotating? I imagine that at one FPS, you have to get the speed just right so that you can have enough control and still be able to span long segments quickly enough.
2) so the device controls whichever application is in focus?
#279724 - 25/04/2006 22:35 Re: Simple video editor software needed [Re: boxer]
I just wanted to thank you for introducing me to this software. It's taken away all the pain of Tivo video extraction. Sure, the whole thing is still a multi-step process, but at least the longest step (editing the video) is now drastically shortened. One thing to mention to people who haven't tried it: ad detection. It's very reliable and so far I've used it on a couple dozen videos and it's done very well. I only wish:
a) the UI was a little nicer. Seriously, someone hit this with the ugly stick
b) there was some way to integrate this with the Tivo extraction process
Other than those little complaints, this program is a dream.
#279725 - 26/04/2006 08:21 Re: Simple video editor software needed [Re: Dignan]
Agreed! I've also been using it for about a week now, and it does exactly what I want it to. I'll most likely buy it when the trial ends. Recommended!
#279726 - 26/04/2006 09:45 Re: Simple video editor software needed [Re: Dignan]
boxer
Loc: Yorkshire UK
I've forwarded a link to this thread, pointing out your comments, to the folks at VideoReDo
#279727 - 26/04/2006 12:56 Re: Simple video editor software needed [Re: boxer]
I'm sorry, VideoReDo folks. I appologize for my first comment (but those colors!)
If they're reading this, then one thing I'd love to be clearer is the batch process. Last night I tried to find out how I could run ad detective on a batch of videos. I tried refering to the help file, but it wasn't very extensive. I ran a job that I thought would do the trick, but nothing really happend. It created a COM file, but I thought it would create project files with all the scene markers for each video.
One improvement would be to allow users to save a project from the start. As it is, you have to make an edit before you can save a project.
#279728 - 26/04/2006 13:05 Re: Simple video editor software needed [Re: Dignan]
boxer
Loc: Yorkshire UK
Sorry if I've caused you some embarrassment, I was more concentrating on your Tivo comment, personally, having struggled with some others, I thought the UI was pretty good.
#279729 - 27/04/2006 04:15 Re: Simple video editor software needed [Re: boxer]
boxer
Loc: Yorkshire UK
VideoReDo contacted me about this thread and particularly about the points raised by Dignan, so I've forwarded the email to him. It then seems more appropriate to follow points specific to VideoReDo on their forum: http://forums.VideoReDo.com, or to contact their support at: support@VideoReDo.com.
Pat at VideoReDo asked me to point out that if anybody prefers the Contour Shuttle Express or Pro to Powermate, they have created a couple of profiles, which can be obtained by contacting support.
#279730 - 27/04/2006 10:29 Re: Simple video editor software needed [Re: boxer]
The Powermate is good, but I don't like how a delay often builds up, and then I have to wait for it to stop. But that's the device's fault, I think. That Shuttle Express looks pretty good (the pro looks excessive for my needs).
