#289572 - 09/11/2006 04:51 Need DOS Batch (DIR command) help
Happy Birthday SonicSnoop
Loc: Triangle, VA
Hey guys hows it going.. A friend had asked me some help with a dos batch file. he wanted one where he could enter the dir to scan for mp3's and put it into a text file. Here is the code:
@echo off
set /P dir=Directory: %=%
set /p file=Output File Name: %=%
dir /s /w /b %dir%\*.mp3 > %file%
Is there a way to get this to not show the dir's in front of the file names? Thanks guys!
#289573 - 09/11/2006 07:29 Re: Need DOS Batch (DIR command) help [Re: SonicSnoop]
furtive
Replacing the /b flag with /n will remove the directory names from the file names, but will show the files in several columns rather than a single column. Don't know if this is any help
Rio Karma - now on ebay...
#289574 - 09/11/2006 11:05 Re: Need DOS Batch (DIR command) help [Re: SonicSnoop]
Try this:
@echo off
FOR /R %dir% %%i IN (*.mp3) DO @echo %%~nxi >> %file%
It's slower, but should work.
EDIT: Also note that if the same output filename is used again, it will append to that file instead of overwriting it. That's pretty easily fixable though.
#289575 - 10/11/2006 23:24 Re: Need DOS Batch (DIR command) help [Re: JBjorgen]
Loc: Triangle, VA
Thank you for the replies! HE was able to get it where he wanted with these posts!
