Patrick's memory expansion boards can be great, but they are quite difficult to install perfectly, and even the best installers sometimes have trouble.
This can result in a player with an installed board which doesn't actually work reliably. When that happens, it is often best to just leave the board in-situ, and flip all four bank enable switches off, effectively disabling the board.
The alternative, desoldering the board and removing it, bears a high risk of destruction to the player mainboard.
I have now removed three memory boards. The first time was on one of my own, and I got lucky in that it removed just fine with no damage.
The second time I removed one (same board, actually) resulted in much destruction of test pads and attached traces, requiring a couple of hours of work tracing signals and solding in replacement jumpers. That player has been in good health ever since, though.
The third time was this evening. I began by solder sucking all of the connections, and then gently pried up the VCC, SCL, and GND connections (while heating them with a soldering iron), one at a time to release the bulk of the memory board. So far so good.
Now for the two big groups of test pads.. this is where all of the damage happens. I started heating/prying, but then
got a clue and stopped.
Down to the workshop, bore a 1.3" hole in a scrap of plywood, place hole over the test pads area, masking off the rest of the player & memory board. Apply heat gun on "high", and wait a few seconds.
The memory board promptly fell off, with very minimal damage to the pads -- probably all inflicted during installation and/or the inital prying beforehand.
The player boots up and works perfectly, and the memory board looks like new.
So.. if you ever have to do this,
Don't Do It !!!. Send it to me instead.
Mark
