I've mk2 unit 709, equipped with 20/40gb disks. Both disks have been replaced after failure. I've let the diskbuilder do it's thing and proceeded with loading the software image on it (3.00a11-dev) I've done this procedure little over a year ago with the same diskbuilder and firmware on an identical disk configuration and that went all fine.
This time however, the player boots correctly, if i compare my bootlog with several other bootlogs posted here, but as soon as player binary is started, it just hangs at 'Searching for music...' on the display.
I've run fsck on both disks and followed the default procedure form manual rebuild, which doesn't make much sense as the disks
are anyway empty. I'm completely lost on what might be wrong with this unit and I hope you guys have a suggestion without having
to rebuild the disks and reloading the firmware. As far as I know, that requires a windows machine, which I have no access to on
a regular basis.
Boot log:
bootstrap v1.00 20000601 (hugo@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #20 Mon J
ul 25 19:00:51 BST 2005
Checking for extra DRAM:
c0c00000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 7, serial number 90000705)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff ''
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHR2020AT, ATA DISK drive
hda: TOSHIBA MK4021GAS, ATA DISK drive
hda: TOSHIBA MK4021GAS, 38154MB w/0kB Cache, CHS=4864/255/63
hdb: FUJITSU MHR2020AT, 19077MB w/2048kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:c1
Partition check:
hdb: hdb4
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
