I was trying to go back to the developer 2.01 from 3.0 alpha 11 and when I was upgrading the file I had an error when plugging my player in during the flash process. I then restarted then reflashed with the 2.01 file and when I restarted it got stuck. I have since reflashed it several times succesfully but can still not get past the boot logo. A recent attempt gave me a Bad Pump Response 0x25 error.....please help!
also here is my boot log
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)oot
empeg-car player (hardware revision 9, serial number 30102295) 16MB DRAM who wants to upgrade the flash, let them speak now,
Command line: mem=16m
Calibrating delay loop... 207.67 BogoMIPS: P
ide_da
Memory: 15008k/16M available (988k code, 20k reserved, 364k..................
Linux NET4.0 for Linux 2.2004
Processor: Intel StrongAR
hds
IP Protocols: ICMP, UDP, TCPead 0
ide_
c1000000: wrote ffffffff, read 9affff
NetWinder Floating Point Emulator V0.94.1 (
Starting kswapd v 1.5 Corp.)0xaaa5D1
SA1100 serial driver version 4.27 with no serial options ena
Speed checking /d
B
empeg display initialised.y Computer Society NET3.03
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg usb initialised, PDIUSBD12 id 10000 (irq
empeg single channel IDE
empeg a
Probing primary interface...revision a0
ide_data_test: wrote 0x0000 read 0xff80l-A to enter pump...
ide_data_test: wrote 0xffff read 0xff80tton initialised.
ide_data_test: wrote 0xaaaa read 0xaa80ar bootstrap v
emp
ide_data_test: wrote 0x5555 read 0x5580
e
ide_data_test: wrote 0x0000 read 0xff80 (save to
ide_data_test: wrote 0xaaaa driver in
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9100823A, ATA DISK drive
hda: ST9100823A, 95396MB w/8192kB Cache, CHS=12161/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:f
7
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initKernel panic: No init found. Try passing i
nit= option to k
Edited by deadsled13 (24/09/2007 02:09)
